Say you have a rectangle that is located somewhere in space, how can I tell the exact x,y coordinate where the rectangle is at?
If you know where you "want" it to be located, put a point at that location by say putting a point at the intersection of two lines. Then "measure" that point and find its X Y and Z location. Then use the translate function to move it in all three axis's at once right to zero.
Many files I am sent are way off in outer space and I have to bring them down to Earth.
Mike
May add that if you are working with a Solid you will need to Extract edges in order to do this.You may also use Entity summary.
Thanks guys, I thought that I had tried the measure entity before, but I must have done something wrong, it's working fine now.
Using the "pick+Pick" method.
http://youtu.be/ul1GUl412qU
You can also combine the "Pick" and "Enter".
(Been trying to get this posted for a couple days... )
Good Job Burr,learned something at the end of the Video.Thanx
