Is it alright to use paint thinner (mineral spirits) to clean up the marking on a Granite Master Surface?
It will not hurt the rock, but the best cleaner is GoJo non abrasive hand cleaner!
www.widgitmaster.com
It's not what you take away, it's what you are left with that counts!
Starret makes a surface plate cleaner that isn't very expensive and works extremely well. Also, keep 'em covered. Mine picked up an amazing amount of debris until I got a cover for it.
Best,
BW
I've found that some soap and water, then finish off with Acetone leaves a nice non oily, non sticky surface that the height gage just glides around on.
rubbing alcahol
