Hi all,
Hoping someone can clear this up for me, I have a dual voltage (230/415) 3 phase single speed motor powering a saw. It's for aluminium so it will be fairly high rpm, probably at least 1800-3000 at a guess. The motor is rated at 2.2kw, and the 3 phase input is currently wired in star fashion. I have spare 2.2kw Huanyang VFD's I could try, but have held off for now as i'm finding a lot of conflicting posts about the need to derate by 50% when you have single phase in, 3 phase out, although a lot of posts indicate that you only need to derate when it is over 3HP? Some people have also mentioned to not connect the earth from the VFD to a star wired 3 phase motor? Is this not required for the 240v phase reference?
So,
1 - if the dual voltage 3 phase motor is rated 2.2kw, will a 2.2kw VFD suffice, or do I need a 5kw rated one?
2 - with 1 phase in, 3 phase out VFD, the motor wired for star, the ground from the VFD is connected to the ground tabs on the motor?
cheers,
Ian
