585,705 active members*
4,041 visitors online*
IndustryArena Forum > MetalWorking Machines > Tormach Personal CNC Mill > Machine Controller Will not come on ?
    Aug 2011
    37
    So i go out to get some work done today and my Machine Controller will not come on it's geting power the fan is runing/ but the power light is coming not on. My monitor has on it (Cable Not Connected) it a 1100 2 years old ???????
    Nov 2010
    360
    Quote Originally Posted by david parkhurst View Post
    Tormach controller?
    Maybe turn off, unplug, wait a few minutes, try again... I had an iffy supply once that I had to "reset" this way until it died....
    That said, if you sniff the fan area of the supply, can you smell burnt electronics/pcb? Odds are the 5V supply is toast (12V is likely OK as the fan is running.....)
    If you have a volt meter, you might check a spare power connector for 5V and 12V.... Supplies are dirt cheap so you might just run to Best Buy or similar and get one....
    Jun 2006
    340
    Dave,
    Read the Troubleshooting section 9 in the manual.
    Follow the steps starting at the paragraph "Which sub-system should I troubleshoot" (para 9.6.5. for the Series 3).
    If not fixed, gather the details you will gain when troubleshooting and email/ring Tormach if they are open, or post the dets here.
    Aug 2011
    37
    Smile
    Back up and runing ( Bad Video Cable ) Thanks for the help
    Feb 2007
    1041
    I was going to say, did you ask her nice.JK Glad to hear !
  1. I got this idea for a CNC machine controller.
    By podolskiy in forum CNC Machine Related Electronics
    Last Post: 03-22-2012, 01:43 AM
  2. Has anyone used their own pc instead of the Tormach Machine Controller?
    By Smokey911 in forum Tormach Personal CNC Mill
    Last Post: 09-22-2011, 08:25 AM
  3. Need help with machine controller software
    By purecnc in forum DIY CNC Router Table Machines
    Last Post: 05-12-2011, 10:39 PM
  4. new machine need controller board
    By DIRKHALLSZ in forum CNC Wire Foam Cutter Machines
    Last Post: 12-20-2007, 03:14 AM
  5. Does anyone reconize this controller and machine.
    By ReefkeeperCNC in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 06-22-2006, 02:40 AM
