Super duper SX3 hard at work.
In my SX3 I was doing a lot of high speed (well for SX3 @ 3600RPM) milling with end mill.
I initially ran it for 45-60 minutes as the spindle expanded in Z as it warmed.
I eventually found a sweet spot at 10 minutes, where the spindle expansion matched the cutter wear rate( about 40 microns in 35 minutes)
Machine was holding 2.5microns with many added tweaks.
About 11000 machining cycles of 2 minutes each on stainless.
10mm 3FL cutter life 35 minutes. 33 of them to resharpen at a time.
Precision Z control video by neilw20_2008 | Photobucket
Video for the non believers.
All the gibs were reground every 100 hours.
Yes warming up can have an optimum time.
