585,954 active members*
4,502 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > all is good until the feedrate comes
Page 1 of 3 123
Results 1 to 20 of 43
    Apr 2007
    17
    Please bare with my. This is my 1st thread
    We just brought in a used Haas Model VF-E.
    Set it up, Leveled it up.
    Made a warm up program with all rapids and G90 / G91 moves.
    All works great.
    Just loaded a program from a smaller Haas.
    All works great until it reads a feedrate.
    The machine just sits there. It thinks it is cutting because it says running.
    Any ideas would be helpfull.
    Jan 2011
    47
    Make sure there is a decimal point after the feedrate.
    Good luck.
    Jim
    Apr 2007
    17
    there is.
    Any other ideas out there in cnczone land?
    15362
    THREEPT82
    Save the program as text, in MS word etc & post it here, it will be easy to see if it is a program problem, or a parameter setting in your control
    Mactec54
    Apr 2007
    17
    O0056
    (DATE 01 / 03 / 13 )
    (HAAS)
    G54
    G0 G17 G40 G49 G80 G98 G90 G54
    T1 M6 ( 1 INCH INSERT MILL - APKT-1003-PDSR LT-1475 )
    ( RUFF O.D. )
    S1950
    G0 G90 G54 X1.8427 Y.76
    M8
    G43 H1 Z1. M3
    Z.05
    G1 Z-.1212 F22.
    G41 D1 X1.5927
    G3 X1.8427 Y.51 I.25
    G1 X2.4303
    G2 X2.9417 Y.0563 J-.515
    X3.02 Y-1.255 I-10.9367 J-1.3113
    X1.255 Y.51 I-1.765
    G1 X1.8427
    G3 X2.0927 Y.76 J.25 F50.
    G1 G40 X1.8427
    Z-.2424 F22.
    G41 D1 X1.5927
    G1 X2.4303
    X1.255 Y.51 I-1.765
    G1 X1.8427
    G1 G40 X1.8427
    Z-.3635 F22.
    G41 D1 X1.5927
    G1 X2.4303
    What parameters would control feedrates?
    Dec 2008
    717
    You're using rapid for the warmup?
    On the program you posted I assume it gets to the G1 line and sits there with the spindle on?
    Tim
    Apr 2007
    17
    Correct.
    It stops at " G1 Z-.1212 F22." but the screen says its running.
    I took this program from one smaller Hass that runs great to this machine as a good job to start with and thats what I get.
    Nov 2007
    1702
    Just a stab in the dark here: is Inverse Time Feedrate turned off?
    Greg
    15362
    THREEPT82
    Put your program together like this sample & you won't have any problems
    Make sure your warm up program is not doing rapid moves, should only be feed moves
    Attached Files Attached Files
    Mactec54
    Apr 2007
    17
    Inverse Time Feedrate turned off? I will check that.
    Should it be on or off?
    That is a section of the program.
    Nov 2007
    1702
    Inverse Time Feedrate should be off.
    What about units? Are you in Metric or Inch?
    Are the position counters moving at all or is it actually stopped? I've seen times where the feedrate is just so painfully slow that it doesn't look like anything is going on but, it's actually moving (like the missing decimal place).
    Greg
    Apr 2007
    17
    I could not find a Inverse Time Feedrate setting anywhere.
    All is in inch and no movement at all.
    Apr 2007
    17
    Does anyone out there have a PDF of an operators manual for a VF-E Mill?
    Dec 2008
    717
    They are all available online. haas.com
    Tim
    Apr 2007
    17
    On line has only new updates.
    Im looking for an original 1998 machine/operator manual.
    I downloaded the Haas site manual.
    It was informative but most didn't pertain to my machine.
    Dec 2008
    717
    You sure it is much different? The 1996 machines I ran were very much the same as far as the operating manual to the 2006 I have...at least for what we are probably dealing with here.
    I'll bet Donkeyhotey is on the right track as far as suggesting some strange parameter or setting. Any of the manuals should be able to get you on track regarding those.
    I'm surprised none of our resident Haas techs have chimed in.
    Tim
    Apr 2007
    17
    I was just on the phone with a tech from Haas.
    He gave me a few things to try which I will tomorrow but he didn't feel they will help.
    I'm just trying avoid a service charge but if I need to, I will.
    I will take another look @ the downloaded manual.
    Thanks Ken
    Dec 2008
    717
    You may want to take a look at the Current Display Command page and compare it with the other machine when it is at that spot in the program just to see what may be different.
    Otherwise - will the program run through on the graphics page?
    Tim
    Apr 2005
    713
    Tim asks a good question: Will it run in graphics ok?
    G91 G1 X5. F50. Run it in MDI and see what happens. Same thing for Y and Z. If nothing happens, try F500. or whatever your max is. I'm not saying this will prove anything, but it's free.
    Nov 2012
    Could be that the machine is locking up on some cutter comp issues.
    I have seen the older haas machines do weird things during cutter comp exit moves. I have also seen some completely ignore the feed rate commanded and run one from elsewhere in the program. Just a few things to check.
    In current commands screen, does the active feedrate represent the programed feedrate?
    Try removing the G41 and running the program without it. Just cut air. See if this makes a difference.
    The older machines will look ahead and see something they dont like, but they will get hung up on a line way before the problem line. Its pretty aggravating sometimes.
Page 1 of 3 123
  1. Any GOOD free cam software? already searched forum, no good result...
    By effimos in forum DIY CNC Router Table Machines
    Last Post: 08-18-2012, 06:39 AM
  2. Plunge feedrate
    By gbjets in forum CamBam
    Last Post: 01-04-2011, 12:43 AM
  3. feedrate wire
    By qwerty1000 in forum Post Processors for MC
    Last Post: 10-26-2009, 04:11 AM
  4. Feedrate override with MPG
    By foka4 in forum Mach Wizards, Macros, & Addons
    Last Post: 07-04-2009, 10:08 PM
  5. G02, G03 Feedrate !!!!!
    By usb in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 09-16-2008, 01:19 AM
