585,597 active members*
3,635 visitors online*
Results 1 to 6 of 6
    Feb 2005
    37
    How much to charge for CNC plasma time?
    Can anyone recomend a good program for estimating cost for a CNC plasma machine? I just purchased a Plasmacam machine and think I will be going with a 60 amp torch. I'm mainly wondering how to figure out how much to charge based on material thickness, cut time, etc. Is there any method to this or do you just guess? Whats the going rate per hour? Or how should I calculate it? Thanks in advance for all advice!
    Oct 2005
    859
    This is most likely based on your machine. I wrote a qbasic program years ago for our wire machines. Each new machine had a better speed so I built in a machine selection variable. Each machine then had a percentage based on the base value I used from our first machine.
    All basic speeds should be supplied by the machine builder. These speeds are effected based on many factors like material and thickness. A spreadsheet could be used to do this but someone would have to fill in all the nominal values. First I would contact your machine tech support to see if this has already been done. Most builders have this type of info in some format so they can compare for sales. However it may only be a basic list.
    BTW: I have found you should stay around 70%-90% of what the tech says it will cut.....this is not a perfect world and the numbers are usually based on a perfect cut condition. I actually put a cut condition variable in my program to calculate % of perfect cut scenario.
    Jan 2006
    Re: How much to charge for CNC plasma time?
    Attachment 241724Click image for larger version.
    Here's a very simple program i use that seems to be fair and doesn't lose me money.
    Mar 2007
    18
    May I request for a copy for the program. I can be contacted on my email [email protected]
    Metalcut.
    Jan 2006
    There should be a link in my signature that will take you to the program.
    -Brian
    Edit: apparently not on this forum, goto ? Index page register and there will be a link there. please leave any feedback and if you like the program you're more than welcome to donate via payal at [email protected]
    Mar 2015
    were I can get this?
  1. What to Charge for Plasma Cutting Services
    By rescueweasel in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 01-11-2022, 02:35 PM
  2. How much do you charge for plasma cutting time?
    By john bulba in forum Waterjet General Topics
    Last Post: 07-04-2014, 11:18 PM
  3. Replies: 14
    Last Post: 03-07-2010, 03:24 PM
  4. CNC Plasma Charge
    By cosmiccutting in forum Waterjet General Topics
    Last Post: 03-23-2007, 11:33 PM
  5. Oxy and Plasma burn time available
    By fastolds in forum Employment Opportunity
    Last Post: 12-05-2006, 07:18 PM
