Found these things while looking for Bijur fittings and valves -
http://www.bijurdelimon.com/fileadmi...DI-ZJBM_DS.pdf
They seem interesting for injecting precise amounts of oil into wherever it needs to be. Don't think they're the easiest or best solution for oiling our benchtop machines, but I am curious if anyone knows what sort of pump you'd use with these. Looks like the pumping pressure needs to be between 200 and 300psi, most manual or auto pumps I've seen run about 65psi max.. Any ideas?
Cheers!
