586,005 active members*
5,260 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > Gearbox lube problem (maybe?
    Nov 2006
    490
    I have a 1997 VF2 with 10krpm and gearbox option. Occasionally (every other month of so) I've heard a weird rumbling sound during power up, which *I think* happens during the low/high gearchange. It's hard to tell when the sound occurs since the power up sequence happens so fast, it's either the high gear gearchange or the Z axis homing.
    The machine runs fine, it never replicates the sounds except for the power up which is what makes me wonder if it's something else (Z axis). Anyway, I climbed up onto the mill to see if there was anything obviously wrong from the outside. I noticed there's a radiator for the gearbox oil up there, with hoses leading to/from solenoids and the spindle mount.
    We're going to remove the covering sheet metal this week to investigate a little further, but I wanted to post a picture of the radiator in case somebody here knows how this thing works. (I'm not familiar with the gearbox hardware). Is it normal for one side of the radiator to appear virtually empty of oil? I'm wondering if this means there's a blockage in there or something.
    Thoughts?
    Jan 2004
    539
    I have never had a gearbox machine..but if that pump is running in the picture, that doesn't look right.
    Pump not pumping or restriction in the cooler.
    Gary
    Nov 2006
    490
    Yeah I'm not sure if it's just how the system works, or if it means there's a big problem in there (lol). I have a bucket of the DTE 25 sitting around so I could do an oilchange but it'd be nice to know it won't make things worse.
    Nov 2006
    490
    Update - the oil needed to be changed so we emptied it and realized both of the hoses were actually full and nothing was blocked. Nearest as I can tell the hoses were simply different colors, probably from one of them being replaced.
    Just in case anybody is searching for information, the hose nearest to the fill cap is the inlet to the radiator, and the one further away from the fill cap is the outlet. When you run the spindle it circulates fluid through it which we could see (assuming the hoses are clear).
    Here's the oil path...
    Transmission outlet (bottom of trans) > oil circulatory pump > filter > radiator > transmission inlet (top of trans)
  1. Mini Mill Lube System Problem
    By Terry G in forum Haas Mills
    Last Post: 06-28-2012, 05:38 PM
  2. Diagnosing VF-0E way lube problem
    By James K in forum Haas Mills
    Last Post: 09-29-2010, 12:17 PM
  3. Eztrak DX II lube problem
    By Neil Mckillop in forum Bridgeport / Hardinge Mills
    Last Post: 02-22-2009, 06:47 PM
  4. VF-9 Gearbox Pump Problem
    By JoBwan in forum Haas Mills
    Last Post: 04-05-2007, 10:02 PM
  5. RF 45 gearbox problem need help please
    By fc911c in forum Benchtop Machines
    Last Post: 01-12-2007, 11:56 PM
