Really new to CNC so bear with me.
I've seen these Shopbots which look really awesome for starting a small business, small footprint, low cost and seems like its really expandable in its options/heads.
But how does building your own compare to getting a shopbot? Is it worth going through allow the trouble building your own when there's a finished machine lie the Shopbot?
Im looking into working with Carbon Fiber and realize that cutting it with water is the safest way.
Is it possible to build a CNC machine with a flood table so the CNC machine actually cuts the carbon fiber UNDER water?
Is it possible for CNC routers to be submerged like that? (I assume it would be a router doing the cutting of the CF underwater?)
Would this be a better option than a water jet cutter?
Is is possible to build water jet setup with enclosure that will cut CF?
