585,762 active members*
4,136 visitors online*
    Aug 2006
    5
    Newbie: Camtronics Questions
    Hello! I have been a long time lurker but I believe this is my first post. I have had a Mill/Drill similar to the Grizzly G1006 and have always wanted to convert it to CNC. I know that a round column mill isn't ideal but it is what I have. I came across a used Camtronics stepper controller at a great price and bought it without knowing what was inside. It turns out that it has 3x 201 Gecko Drives and two transformers in it with model number 430-9001 by Midwestco. I can't figure out how to post pictures and not sure if this is the correct forum to post this in (as there are a lot of forums). I have a lot of questions but the first three questions I have are...
    1. There is a plug in the back of the box for 5v but there is only one pin in the connector and that pin is running to the Gecko Drives. Is this missing the other pin and wire in the connector or is it using a common ground wire? Or other? Perhaps if someone else could post a picture of how they have this wired would help.
    2. Does anyone know what these transformer provide to power steppers?
    3. Can someone recommend stepper motors that would hopefully work with this controller and power a Mill/Drill conversion? The stepper plugs are 4-wire.
    Thanks in advance for any help. I would like to get the electronics working before I start to convert the Mill/Drill as the electronics are the steeper side of the learning curve for me.
    Apr 2004
    5735
    Camtronics is still in business; you should ask Dan Mauch these questions: Camtronics, inc. -- CNC with Dan Mauch
    Andrew Werby
    www.computersculpture.com
  1. Newbie questions
    By 4lowie in forum Australia, New Zealand Club House
    Last Post: 09-29-2011, 11:38 PM
  2. Newbie with a new X4+ and many questions
    By Mac Tech in forum Syil Products
    Last Post: 01-27-2009, 09:45 AM
  3. CNC Newbie with questions
    By RockyRR in forum DIY CNC Router Table Machines
    Last Post: 07-22-2008, 11:14 AM
  4. Newbie CAM questions
    By WoodSnarfer in forum Uncategorised CAM Discussion
    Last Post: 11-12-2004, 02:15 PM
  5. Camtronics driver questions
    By cncadmin in forum CNC Machine Related Electronics
    Last Post: 07-30-2003, 11:29 AM
