585,604 active members*
3,299 visitors online*
IndustryArena Forum > CAM Software > Visual Mill > how to define chamfer tool?
    Sep 2010
    72
    Struggling on how to define chamfer tool in visual mill. What are the minimum fields that need to have values? Can't find any examples in the docs.
    I'm trying to add this as a new tool for example - 60 Degree Included Angle Chamfer Cutters
    Dec 2005
    231
    I have the same question for AlibreCAM with respect to defining a 1/16" and 1/8" radius round over tool.
    I imagine it ends up being a profile operation with the depth set to the radius?
    Jan 2004
    3154
    I never bother to define it. Seems a waste of effort IMO.
    I title it a corner round tool but define it as a flatmill the same diameter as the little nose of the tool.
    Next I program it to do 2.5d profile of the edge to be rounded. Use a cut depth equal to the horizontal runout of the cutter form.
    Done deal - simple.
    To tweak the blend on the vertical wall use + or - stock in the profile and for the horizontal surface blending go up or down with cut depth.
    I use a similar strategy for chamfering - the cutter wants to follow the region to profile without under cutting it so just use negative stock setting to get the cutter to cut the chamfer.
    www.integratedmechanical.ca
  1. Chamfer Tool Path
    By warrguitars in forum MadCAM
    Last Post: 02-08-2012, 08:15 PM
  2. Chamfer Tool Question
    By MetalShavings in forum Solidworks
    Last Post: 09-25-2011, 04:06 PM
  3. Using a 45 deg chamfer tool
    By COPO427 in forum Mastercam
    Last Post: 01-14-2007, 07:28 PM
  4. What tool is best? Bevel/Chamfer
    By dneisler in forum MetalWork Discussion
    Last Post: 11-29-2005, 04:44 PM
