I have just upgraded my plasma machine from steppers to proper servos and a USB smooth stepper, which runs great until i start the plasma arc. sometimes mach3 stops immediately, sometimes it takes a second or two. I thought maybe the interference maybe came through the GND wires so i started to disconnect them, everywhere, just to see if there would be any difference (btw nothing changed). As you might have figured out by now, there is a lot of guessing involved here. Another thing i did (might worth mentioning that i did this first) was to bypass my breakout board. good? bad? From the pictures you might find out something that i did extra wrong or so.
Here is that error message i get:
"Error returned from USB function FT_white."
"Error: FTDI USB Driver Error"
"Error = FT_IO_ERROR"
"Bytes requested: 64"
"Bytes written: 0"
To the question. Does anyone have any idea what to do next? or should i start searching for a resting place for the USS under something very very heavy?
