Any progress?
Any progress?
It's been a CRAZY summer and this project had to be put on hold. I now have more time and expect to start building this thing soon! I have made lots of changes. Please take a look at the latest design pictures and let me know if you see any red flags. Some of the parts in the picture below are already purchased. So I'm in deep now and there will be no turning back! I have found this project to be WAY more difficult than I thought it would be. I need all the help I can get!
Attachment 196598
Attachment 196610
Attachment 196612
Attachment 196608
Attachment 196606
Here are the parts I have already purchased.
Attachment 196614
Here is the master parts list and still growing . . .
Rutex:
4) R2110 - Non-polarized motherboard - 5 volts.
1) R2010 - Servo drive for brush motors 100V/20A
4) R2210 Single ended TTL encoder interface
1) Chassis
Automation Technology Inc
3) NEMA34 850 oz/in Dual Shaft DC Servo (KL34-170-72)
1) NEMA34 600oz/in Dual Shaft DC Servo Motor (KL34-150-90)
3) KL-34GH101 10:1 Planetary Gearbox 4000RPM
1) SmoothStepper USB Motion Control Board for Mach
eBay
Electroid NEMA 34 Power off brake
Misumi ball screw
Digi-Key
4) 102-1307-ND ENCODER PROG 16RES SW TTL RADIAL
Ugracnc.com
7 ft) Cable Carrier 25 x 57mm
5 ft) Cable Carrier 25 x 37mm
Misumi
1) GFS8-100200 100 X 200 X 1850 Extrusion
2) HFSP5-4080 (milled) 40 X 80 X 3000 Extrusion
1) Bulk pack T-nuts
Automation-overstock.com
4) Product ID: AGH15SAZ1H
Product Name: 15mm Bearing Block, 2 Bolt Square
2) Product ID: AGR15RxxxxH
Product Name: AG Linear Rail, 15mm, 449mm
4) Product ID: AGW25SAZ1H
Product Name: 25mm Bearing Block, 2 Bolt Flange
2) Product ID: AGR25RxxxxH
Product Name: AG Linear Rail, 25mm, 1850mm
4) Product ID: LGH25HAZ0H/E1
Product Name: 25mm Bearing Block, Long Square, Self Lubed
2) Product ID: LGR25RxxxxH
Product Name: LG Linear Rail, 25mm, 3000mm
More gear
R & P gear - 20 Pitch 20 PA
Pinion 1" Dia
Blurry Customs
1) Spindle (MT1073 - Y6162Y0017)
Power S1/S6: 3Kw/3,60Kw
Connection type: Collet ER25
Rated voltage: 220V
Rated speed: 18.000 rpm
Max speed: 24.000rpm
Rotation: Right
1) VFD ( Delta VFD055B23A) & cable
Misc parts
1) Servo power supply
Cooling fans
Steel for table
Aluminum for z axis, servo mounts & z axis parts
Fuse sockets
Limit switches
Software
I think it looks great. The overkill on the structure will allow for a higher horsepower spindle in the future if necessary. You show 1 servo drive, you need 4 I think. One thing I would do before proceeding is to source your control panels, and do a rough back panel layout. You want to make sure you don't run out of space. 10" deep should do for the VFD panel, and maybe 8" for the other. Too deep just makes it difficult to work on. They're expensive new but you can find deals on eBay if you're lucky. Looking forward to seeing your beast running!
Kevin
Kevin,
Looks like I had 1 servo drive and 4 motherboards. That wouldn't work! Good idea on the control panels. If anyone out there has one for sale let me know. I'll start trolling eBay and see what I can find.
Here are a couple more views:
Attachment 196698
Attachment 196700
Am I the only one here with an opinion about this machine?
Kevin
I'm waiting on production of all that structural tubing, the machine is only as good as its main support structure!
So far the concept looks solid!!
Widgit
www.widgitmaster.com
It's not what you take away, it's what you are left with that counts!
I'm going meet with a local machine building company next week. They may be able to supply the steel and cut all the parts. In the end I will have a table kit ready to assemble. I hope they can do it because my cutting tools are very limited.
- Allen
Attachment 197274
The drawing looks good Allen. Are you going to change your enclosure mounting provisions to fit standard size enclosures? I would make room for at least 16" tall, or 20" if possible. Even then you will probably need two side by side for controls. Two 16X20X8's might be okay but even that tight makes things pretty difficult. Have you considered a free-standing enclosure at least for the non-VFD controls like this one?
Hoffman Enclosure 36"X36"X12" Nema 12 CSD363612 With Backplate Stand | eBay
That could leave you room for future changes like larger servo drives, etc. plus isolate your electronics from vibrations. It's aslo better for cooling. Just a thought..
Kevin
I like the idea of putting most of the electrical components in a stand alone box. So I just purchased this 60" x 30" x 11" box on eBay.
Attachment 198520
Yea . . . it needs a little paint! However, it should have plenty of room for anything I may need in the future.
I have not met with the machine building company yet. The guy in charge was on vacation. So I hope to meet with him next week.
Still waiting for more quotes on steel. In the meantime I decided to mill the riser out of MDF to verify everything is correct. The aluminum is going to be expensive and I can't afford to overlook anything. The mill cut the MDF as expected and I plan on checking the alignment with the mating parts as soon as they come in. If all looks good I'll move forward and mill the 1" thick 6061 aluminum. It's nice to see a a physical part after looking at CAD for so long!
Just received the Misumi extrusions. They look good. I was surprised the big Y extrusion was so heavy. That thing is 72" long and weighs 82 lbs.
Attachment 201400
The servos and 10:1 ratio gearboxes also came in. Lots of parts and still no steel for the table. Gonna have to step up the search and get some quotes.
Attachment 201402
The 3" x 3" x 3/16" steel box tube I'm using on my own build has a listed weight of 6.87 pounds per foot of length. That would be 82.44 pounds for a 144" length. I have one extra 12' piece that I'm tempted to weigh on bathroom scales just to see if the calculated weight is close to the measured weight. I too would have expected the extrusion to not weigh that much.
CarveOne
http://www.carveonecncwoodcraft.com
Finally got the electrical box painted!
Attachment 207218
Sublime green & black.
Steel and aluminum came in a few weeks ago. I decided to buy a little extra steel for a welding table. The CNC table will be my first ever welding project. Since I didn't have a welding table I thought it would be good practice to design and build one.
Attachment 207252
Lots of steel
Attachment 207254
Inventor model
Attachment 207256
3' x 3' x 1/2" laser cut top and the rest of the steel ready to be welded.
Attachment 207258
Spot welding the 1/8" thick shelf in place.
Attachment 207260
Now that the welding table is done, I feel a little better about moving forward with the CNC table. It's go time!!
All the steel is cut for the CNC router table. The next step is to drill the mounting holes in the 3" x 6" side beams to attach the 10' aluminum extrusions. However, I noticed quite a sag in the 3" x 6" beam sides. I knew I would need to shim the extrusions flat but this is not what I expected. Hopefully, shimming them will not be as hard as it looks.
Attachment 207262
Attachment 207264
Aw man, you went and picked my colors and beat me to it!! I have a gallon of that bright green stuff ready to go on my new frame, maybe this weekend. Gloss black is the trim color. I'm using the Jeep Wrangler mix.
CarveOne
I'm using TCB Global's Restoration Shop Sublime Green and Jet Black. It's a 4:1 ratio acrylic urethane. I always loved the old Mopar green! The Jeep green is probably close to the same color. You'll love it!
It has become a popular color. I have Stanley tape measures, Post-It notes, and see it everywhere now. Even my roadside trash bin is this kind of green and black.
CarveOne
The extrusion mounting holes are done. 3/4" socket clearance holes on one side and 3/8" holes on the other. I pre-drilled all the holes with a 1/8" bit. For the 3/4" holes I used a step drill. That was an easy way to drill the big holes in the 1/4" thick steel. 40 holes in each 3" x 6" . . . lots of drilling!
Attachment 211214
With a hand drill, no less -- that's patience.
David Malicky
