585,556 active members*
3,681 visitors online*
IndustryArena Forum > MetalWorking Machines > Bridgeport Machines > Bridgeport / Hardinge Mills > Bridgeport CNC Quill Motor Pulley and X-axis Belt
    Jan 2013
    I have a 1979 Bridgeport Series I CNC mill. The aluminum quill motor pulley has 26 teeth, 4" diameter, 5/8" shaft, Bridgeport part number 2-77-0134, and uses a 300H075 drive belt (Bridgeport part number 1-77-0232). My quill motor pulley is 1:1 with the quill. Does anyone know the generic part number part number and recommended source for this pulley?
    Also, does anyone have the correct generic part number for the x-axis belt (Bridgeport part number 1-77-0063)?
    Scott
    Dec 2008
    239
    You can see the mechanical Drawing in the manual of the machine , You will find the Correct part Number . Or else you can communicate the MTB ( machine tool Builder)
  1. Toy Motor Brass Belt Pulley
    By rwburbage in forum Employment Opportunity
    Last Post: 11-15-2012, 02:45 AM
  2. X3 Motor Pulley / Belt Pitch?
    By ImagineRobots in forum X3/SX3/G0619/G0463
    Last Post: 01-18-2012, 03:43 AM
  3. Pulley size for Bridgeport 1J head motor replacemet
    By PhoenixMetal in forum Bridgeport / Hardinge Mills
    Last Post: 03-09-2010, 04:29 AM
  4. bridgeport 2j belt for step pulley
    By patrick71100 in forum Bridgeport / Hardinge Mills
    Last Post: 11-02-2007, 05:28 AM
