585,997 active members*
4,793 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > DNC Drip Feed CNC88HS VMC10-15
    Jun 2012
    16
    Hey guys I am stuck with this problem of not being able to get my VMC to communicate with the PC for DNC.
    I have OneCNC-DNC free software and I keep getting a parity error on the Fadal control. My Fadal control is a 1994 CNC88HS.
    My Port settings are:
    Baud rate:9600
    Data bits: 7
    Parity: even
    Stop bits: 1
    XON/XOFF: enabled
    DTR/DSR: disabled
    RTS/CTS: disabled
    The Program has 12,354 lines but I cannot even get it started. Do I just type DNC at the prompt or DNC,0,1,0,1 to activate the correct DNC mode?
    Matthew D.
    Jun 2012
    16
    I was able to start the DNC
    I initially set the control to CD,10 for the (38,400), then at Manual prompt I entered DNC 0,1,0,1
    At the OneCNC-DNC software I aet the com port 1 to:
    Baud: 38400
    Data bits: 7
    Parity: even
    Stop bits: 1
    XON/XOFF: enabled
    DTR/DSR: enabled
    RTS/CTS: enabled
    100 MS delay
    The machine showed a Waiting prompt. I hit the green button and it was running line by line from the computer.
    Very excited!!!
  1. Drip feed DNC
    By forhire in forum NCPlot G-Code editor / backplotter
    Last Post: 07-09-2011, 04:59 PM
  2. I-80 drip feed
    By ka67_72 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 07-18-2010, 12:28 AM
  3. Drip feed or DNC
    By airlid in forum Mori Seiki Mills
    Last Post: 02-18-2010, 12:19 AM
  4. Drip feed?
    By kotten1 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-08-2008, 08:44 AM
  5. BMC-20 w/Max II drip feed......
    By GPena in forum HURCO
    Last Post: 10-31-2007, 06:37 PM
