585,743 active members*
4,891 visitors online*
IndustryArena Forum > WoodWorking > WoodWorking Topics > 29 cribbage board template
    Oct 2011
    69
    Post 29 cribbage board template
    hi guys and gals i am wondering if anyone has a 29 cribbage board template out there i want to make one any help out there would be great.
    Dave
    djnphotowoodworking
    May 2010
    93
    What software are you using? I was able to easily create a custom cribbage board using Vectric VCarve Pro following the info found here: http://www.vectric.com/forum/viewtop...t=4844&p=32768
    Jan 2007
    1795
    i made a few experimental.. heres one if this is what you was thinking
    i made it with acexpress.. it imports directly models and makes some pictures too if you want to add someones photo..
    if youre tigth on budget ac express makes you everything
    it cost only 150 and i made cool stuff with.. for ac express dont need additional program to milling reliefs or putting a photo on your projects.. it do itself all..
    this program same simple. it just cost a lot less..
    Attached Files Attached Files
  1. Flower template
    By Claude Boudreau in forum Machine Created Art
    Last Post: 08-18-2012, 05:32 PM
  2. Cutting from template
    By StefanV in forum Mach Software (ArtSoft software)
    Last Post: 10-12-2009, 01:05 AM
  3. Template Bulider
    By Tazzer in forum Haas Visual Quick Code
    Last Post: 02-18-2008, 09:24 PM
  4. CNC Setup Template
    By MartinLogan in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-20-2007, 11:02 AM
