Hi everyone,
I have a home built router with 381oz steppers, a 48v 7.3a PS, and a gecko 540. Everything is about a year and a half old and has been running fine till a few weeks ago. Now my gecko keeps randomly "faulting" and I can't figure out why. It will do this every few seconds sometimes and other times I may run it for an hour or more with no problems. I have checked my wire connections at the motors and all looks good.
I have spoken to customer support at Gecko and they think it's a power supply problem. I have tested the voltage of my PS and it is putting out 48.3v. They also told me to jog the motors 2 at a time to see if it faults. Sometimes it does, sometimes it doesn't. It is completely random. I sometimes get a red fault light while jogging 1 axis(sometimes x, sometimes y, and sometimes z so I can't narrow it down), any 2 axis', or all 3. a few seconds later, I can do the same test with no faults, even while jogging all 3 at the same time. Once yesterday and twice today it actually faulted while sitting completely still with no motors operating. It has only done this these 3 times. Usually it does it while the motors are moving. Today it faulted more than a dozen times while carving a 2 inch tall letter "A" while running at 100ipm which is where I normally run it(usually 100-120 but occasionally I run this machine at 280-375ipm or more). I then turned it down to 60ipm in Mach 3 and it finished the"A" and then carved a dozen more letters with no faults. Any ideas of what else I should look for. Thanks for any help you can offer on this, Jeff
