This is from International Rectifier.
http://www.irf.com/product-info/imot...alcontrol.html
They have like modular chips system call: iMotion chip set.
Description
IRMCK201 is a complete AC servo motor control IC. It contains closed loop current control for sinusoidal AC current, and closed loop velocity control based on encoder position feedback interface. A standard communication port is provided for RS232C or RS422, in addition to a fast SPI communication interface. Unlike a traditional DSP or a microcontroller, the IRMCK201 does not require any programming effort to complete the complex control algorithm. It allows users to configure the algorithm for specific application needs. Permanent magnet motor or AC induction motor are supported. IRMCK201 facilitates high performance servo design together with the IR2175 current sensing IC and IR213x high voltage 3-phase gate driver IC, which simplifies the hardware design while minimizing cost. For multi-axis applications, IRMCK201 can be used as a multi-drop slave drive based on the SPI protocol. The package is available in a 100-pin QFP.
Overview
IRMCK201 is a new International Rectifier integrated circuit device designed as a one-chip solution for complete closed loop current control and velocity control for a high performance servo drive system. Unlike a traditional microcontroller or DSP, IRMCK201 does not require any programming to complete complex AC servo algorithm development. Combined with International Rectifier’s high voltage gate drive and current sensing IC, the user can implement a complete AC servo control with minimum component count and virtually no design effort. Although IRMCK201 contains dedicated logic to perform closed loop control of AC current and velocity, it has a wide range of application coverage through its flexible configuration ability. The drive can be easily configured for induction machine closed loop vector control or permanent magnet motor servo drive. Rich motion peripherals, analog and digital I/O can also be configured. Host communication logic contains an asynchronous RS232C or RS422 communication interface, a fast slave SPI interface and an 8-bit-wide Host Parallel Interface. All communication ports have the same access capability to the host register set. The user can write to and read from the predefined registers to configure and monitor the drive through these communication ports.
They even sell a KIT " It is the driver READY TO RUN"
"Complete Encoder Based Servo Drive Design Platform
iMOTIONTM Development System"
3.1 Readily Drivable Motor List
If the motor is one of the following, it can be run immediately without commissioning.
• Sanyo Denki 400W 8-pole servo motor with 2000-pulse encoder (P30B06040DXS00M,)
• Sanyo Denki 750W 8-pole servo motor with 2000-pulse encoder (P30B08075DXS00M)
• Sanyo Denki 1.5kW 8-pole servo motor with 2000-pulse encoder (P20B10150DXS00M)
• Glentek 160W 4-pole servo motor with 2000-pulse encoder (GMB2010-17-E-02100005)
• Glentek 1.0kW 6-pole servo motor with 5000-pulse encoder (GMB3530-24-E-02200109)
• Glentek 1.2kW 6-pole servo motor with 5000-pulse encoder (GMB3530-37-E-02200109)
• Glentek 600W 6-pole servo motor with 5000-pulse encoder (GMB3530-48-E-02200109)
• Pacific Scientific 800W 8-pole servo motor with 2048-pulse encoder (PMB23C-00114-00)
• Reliance Electric 2HP 4-pole induction motor with 1024-pulse encoder (P14A5805)
If any other motor is used, adaptation and re-configuration is required, which can be accomplished using the
ServoDesignerTM tool.
