X,Y axis working area
300 x 200mm
Z axis smallest cnc working area
<60mm
Table size
370 x 440mm
Max. speed
0 - 4,000mm/min
Max. working speed
0 - 4,000mm/min
Working delicacy
0.015mm
Reposition accuracy
0.05mm
Max. Feeding height
60mm
Command
G code *.u00 *.mmg *.plt
Software
type 3 , Artcut, artcam,Ncstudio
Max. power consumption
1.2kW
Spindle
0.8KW variable speed, water cooled motor
Spindle speed
24,000rpm
Work type
stepper
Relative humidity
30% - 75%
Working voltage
AC 220V, 50/60 Hz
Weight
57kg
Manner of receiving data
USB OR PCI
Running circumstance temperature
0 - 45°C
SAMPLES
AFTER SERVICE
Guarantee for one year.
24-hour technical support by email or calling
I f necessary,we can send our technical personnel to to your country to offer help.
CERTIFICATE
CE&FDA
KEY POINTS
Please kindly tell us your engraving or cutting materials, and materials’ size.
Then we can quickly check and recommend to you the right machine with right working area.
We can change all the parts of the machine according to customer’s request,such as the spindle (air cooled or water-cooled optional ),guide rail (linear guide rail or square linear guide optional ), the motor (step motor or servo motor optional), the table size of the machine and so on. If you are interested in our products,pls contact me.We are looking forward to cooperating with you.
Any other doubts, just feel free to let me know,Thanks for your kind attention!
