Hello,
I'd like some opinions please...
...We have a horizontal machining center with a Mitsubishi Meldas 300 controller and there is a part we are looking at that has a couple tapped holes coming in from the side (so a 90 deg head is needed) AND at a 56 deg angle (when looking at the part from the spindle, starting at 3 o'clock ... this would put the holes in the X+Y+ quadrant). Anyway, we'd have to tap while moving the X-axis and Y-axis simultaneously. I can't use a G84, obviously, because that feeds the machine in the Z-axis. What do you think the chances of success are if programming this point-to-point? Something like this (these are made-up numbers, but you get the drift):
G0G20G90G94S361M3
G54X2.5500Y10.4531B0.000
G43Z-1.5000H1
G1X3.5589Y11.5839F19.0M8 (start feeding into the hole with the tap)
M5 (stop the spindle)
G4P500 (maybe add this dwell to make sure the spindle stopped?)
G1X2.5500Y10.4531F19.0S361M4 (Start the spindle CCW & feed back out)
G0X1.0000Y9.0000
G0G90G53Z0.W0.
(ETC., ETC.)
Thanks for any input...
