584,842 active members*
4,614 visitors online*
Results 1 to 11 of 11
    Aug 2003
    812
    Mazak T2 parameter input format?
    This is on a QT-8 with a T2 control.
    I need to change parameter OP-5 to tell the control I have the tool setter back on. I have the parameter list and what 0s to change to 1s. I found out the control wants these left to right...got that far. I try and type in 00001000 but the control won't accept it.
    The bits are displayed as 0000 0000 with a space between the groups of 4. I don't have a space key on the control and that may be where the problem is. I tried putting a 0 there and . and -. Did not work either.
    Anyone know how to type this in?
    24216
    With the parameters, you need to add a parity bit (9 bits) so if you are entering 00001000 you add a 1 on the end for the one bit set.
    e.g. 000010001 if it was 00001101 the entry would be 000011013
    Al.
    Albert E.
    Aug 2003
    812
    Wow thanks Al. I would have never figured that one out. A guy on the PM board said the same thing.
    Appreciate the help.
    Dave
    May 2016
    5
    Hello does anyone have a hardcopy of parameters for a QT15 MAZATROL CAM T2 1989
    PLEASE HELP
    Sep 2013
    Hi Did you manage to find the parameters for your Mazak?
    Nov 2019
    18
    Re: Mazak T2 parameter input format?
    HELLO
    need all about MAZATROL CAM T2
    24216
    P.M. me email add
    Albert E.
    Jul 2007
    26
    Al.
    I don't know parameter code OP1-OP16.Can you help me?
    Thanks.
    24216
    Quote Originally Posted by sun View Post
    Thanks.
    What machine is this?
    Albert E.
    Jul 2007
    26
    Mazak QT15 Mazatrol Cam T2
    Nov 2014
    Hi i am need help for parameter quickturn20 by mazatrol cam t2
  1. mazak 640t decimal format parameter ?
    By rapid in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 10-29-2011, 09:27 PM
  2. Replies: 0
    Last Post: 05-23-2011, 11:28 PM
  3. Fanuc 10M Parameter input
    By nastek in forum Fanuc
    Last Post: 10-05-2009, 10:01 PM
  4. Fanuc 7M parameter input
    By greenery_fr in forum Fanuc
    Last Post: 05-27-2009, 02:13 AM
  5. Meldas M0- cannot input xyz axis parameter
    By Place2809 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 11-22-2008, 05:55 PM
