585,933 active members*
3,816 visitors online*
IndustryArena Forum > CNC Plasma, EDM / Waterjet Machines > Hypertherm Plasma > connecting hypertherm 65 plasma to cnc
    Feb 2010
    5
    hi, I have K2 cnc model KG9850 router, currently working with wood.
    I want to try something new and would appreciate any advice on connecting a machine torch hypertherm 65 plasma to the cnc.
    can i connect it via the control box relay?
    will appreciate any help. thanks.
    Kris
    Jan 2008
    2247
    If the Powermax65 has the optional CPC interface receptacle (on the rear panel)...then you can interface the start signal on pins 3 and 4 on that connector. To fire the plasma, assuming it is powered up, has an adequate air supply and consumables in the torch, simply short pins 3 to4, to stop the torch, open the connection between pins 3 and 4.
    You will need a contact closure output from your cnc control. I suggest contacting K2 to get suggestions on how to connect an output relay, as well as how to adapt the program to start and stop the plasma torch in the correct locations for the cut path.
    Jim Colt Hypertherm
    Quote Originally Posted by unixi407 View Post
    Kris
  1. Need HELP connecting Hypertherm 105 to Breakout Board
    By HIDesigns in forum Waterjet General Topics
    Last Post: 08-28-2015, 08:52 PM
  2. Hypertherm plasma quench
    By Danno in forum Hypertherm Plasma
    Last Post: 03-14-2015, 11:34 PM
  3. Z-axis goes crazy when connecting plasma ground clamp... please help
    By Killerdub in forum Waterjet General Topics
    Last Post: 09-14-2010, 08:07 PM
  4. hypertherm plasma cnc
    By woodman08 in forum Waterjet General Topics
    Last Post: 12-15-2009, 03:12 PM
