585,982 active members*
4,667 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > pop bottle cap thread
    Nov 2004
    85
    I have BC v25 and need to make a 3D solid model for my 3D plastic printer of pop bottle cap threads that can screw onto a 2 liter bottle.
    I believe the threads are stubby 8 tpi ,.450 length, I.D. of 1.00".
    Anyone have an idea of how to draw these threads? Outside of cap isn't important at this stage, just need to know how to draw the threads for solid modeling. Thanks, RJ
    Dec 2008
    4548
    Here's a file with some geometry to look at. On the "normal" layer, there is a helix and a profile. This would be a normal way to make a thread solid for "cutting" thereads out of a cylinder. BobCads "sweep" command doesnt handle this well (It needs an option to define the "flat" of the sweep, so you would need to construct it by surfacing.
    To see what you would need to do, just look for the green "Cutter" object and make that the only thing visible and active. Then extract it's edges (From Solid)... You will see 2 profiles one on each end and 4 helixes that makeup the wireframe. 2 inner ones that and 2 outer ones. From these you can skin the solid (That you see in green) that you can use to boolean difference from the inside of your cap shape to make internal threads on a cap.
    Attached Files Attached Files
    Dec 2011
    361
    Draw the helix for the thread at the depth that you want. The helix function can be found under Other/Spiral. Then draw the profile of the thread. Then use the sweep function to sweep the profile along the helix. I have provided PDFs on the Spiral function along with the Sweep function.
    Dec 2008
    4548
    Sean,
    Have you tried that in BobCad?
    Open the example I posted and look on the "normal" layer. Sweep that profile up the helix.
    There is an automatic rotation to sweep that occures due to the structure of the helix. In a program that will accomplish this, there needs to be a "set flat" option, which will maintain the profiles "Flatness" throughout the sweep. (The solid in the file I posted)
    Maybe you can share this with the geometry guy's to look at updating the sweep command?
    Other than that, you will need to skin the wires to make it. (Or use another CAD package that will do a flat sweep)
    Or, maybe you could enlighten me on a rotation/placement of the profile and a pick method to acheive a flat sweep up the helix.
    Dec 2008
    4548
    I was thinking about a bottle cap, and there ARE different kinds, like the little tin ones that break at the bottom when you twist it... Those arent really "internal threads", but are actually shaped like the threaded surface.
    Here's another method to get those types. Although I made an exaggerated shape, and also use a spline (I think a true cross section of that type of thread would use straight lines with arcs where the thread is) As long as you use the true profile/cross section of the cap it should produce one of those this way:
    Bottle Cap - YouTube
  1. Bottle Jack up side down
    By jeffrey001 in forum Bending, Forging, Extrusion...
    Last Post: 03-05-2013, 11:38 PM
  2. cinci milacron arrow 1250 - gas bottle
    By m@chinist in forum Cincinnati CNC
    Last Post: 11-20-2010, 09:06 AM
  3. Soda bottle threads
    By cfordyce05 in forum Solidworks
    Last Post: 06-20-2010, 08:13 PM
  4. Bottle Opener
    By sluggo in forum MetalWork Discussion
    Last Post: 01-13-2007, 11:06 PM
  5. DIY Lifting Cart using 4 bottle jacks!
    By damae in forum Uncategorised MetalWorking Machines
    Last Post: 06-07-2006, 11:51 PM
