585,996 active members*
3,850 visitors online*
IndustryArena Forum > CAM Software > Vectric > middle of letter
Results 1 to 9 of 9
    Jan 2013
    middle of letter
    Hello,
    I am French , so sorry for my English.
    I'am manufacturer of sign and I search function in Vectric.
    I want to automatically trace the middle of a text or letter and I would like to export in eps or dxf.
    I currently use the pen to draw the middle of a letter, but it's very too long
    An example in the attached file, the middle of the text is blue
    http://img32.imageshack.us/img32/7172/milieub.jpg
    Do you know a other software that can do this function?
    thank you
    Michaël
    Jun 2008
    562
    Quote Originally Posted by mickey83 View Post
    Hello,
    thank you
    Michaël
    Vectrics Vcarve text routine has sigle line fonts that you can profile carve to the depth you would like or export to DXF. Or you can do a regular Vcarve routine.
    Mike
    Jan 2013
    Hello
    Thank you for your answer,
    yes this is what I want,
    but if, I export in dxf , the middle line will stay ?
    If you have a tutorial, it's very cool
    thanks
    Jan 2013
    Re
    I just tried,
    I can trace the middle of the letter,
    but how to export the line in the middle eps, as I can not to select and when I export the middle line don't appear.
    an example in the photo attached
    thanks
    Jun 2008
    562
    I just tried,
    thanks
    You don't trace the middle of the letter. Highlight the single line font, then do a, File, export, to eps. See the help menu
    Jan 2013
    re
    ok,
    sorry I do not speak well,
    I create a text sign in Illustrator,
    I import this text sign on vcard and
    I want the middle of the letter as in my example attached
    and I want to export eps to to continue working in drawing Illustrator
    Jun 2008
    562
    ok,
    I thought you were talking about the Vectrics products! Can't help you with Illustrator.
    Jan 2013
    It does not matter, I spoke well of a function on Vectric,
    because this function is not disponible on illusrator.
    and if I want this feature is disponible on Vectric and then exported to Illustrator
    thanks
    Jan 2007
    1795
    mickey
    i attaching a postprocessor.. this is the dxf postprocessor..
    before start program, find the folder that contain postprocessors..
    copy this dxf.pp there.
    file is dxf.txt you need to rename to dxf.pp forum dont let upload pp extension..
    start program and make toolpath
    save toolpath, and set this postprocessor
    Attached Files Attached Files
  1. Letter cutting help
    By D-M in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 03-20-2012, 03:31 AM
  2. Help with Letter Design
    By jharvey407 in forum Signmaking Topics
    Last Post: 02-27-2012, 03:07 PM
  3. Letter spaces
    By Fabio1 in forum Fanuc
    Last Post: 09-26-2011, 01:41 PM
  4. Open letter
    By Mariss Freimanis in forum Open Source Controller Boards
    Last Post: 01-31-2009, 12:56 AM
  5. letter cutouts
    By AndrewB in forum Autodesk
    Last Post: 01-12-2008, 06:48 AM
