585,754 active members*
4,260 visitors online*
Results 1 to 6 of 6
    Jun 2012
    Xilog - Record 220 programing
    I have fairly recently started using a SCM Record 220 CNC and I would like to write a little python program to write an xxl file for a particular task here at this shop. I started by writing a script to output an xxl file for a very simple rectangle. I convert the xxl to pgm using a program called WINXISO.EXE that has worked in the recent past to convert other xxl files.
    When I try to load my new pgm file in the Zilog program to cut it I get an error:
    "xMETALine 17) Invalid Correction of fset for the segment."
    The code I make the pgm file from looks like this:
    H DX=97.000000 DY=48.000000 DZ=0.750000 BX=0.000000 BY=0.000000 BZ=10.000000 -AB C=0 R=1 *IN/"STANDARD"
    F=1
    C=1
    G0 X=5.000000 Y=0.000000 Z=0.250000 E=1 V=8 S=17000 T=150 N="outside"
    G1 X=5.000000 Y=0.000000 Z=-0.375000 V=8
    G1 X=10.000000 Y=0.000000 Z=-0.375000 V=8
    G1 X=10.000000 Y=20.000000 Z=-0.375000 V=8
    G1 X=0.000000 Y=20.000000 Z=-0.375000 V=8
    G1 X=0.000000 Y=0.000000 Z=-0.375000 V=8
    G1 X=10.000000 Y=0.000000 Z=-0.750000 V=8
    G1 X=10.000000 Y=20.000000 Z=-0.750000 V=8
    G1 X=0.000000 Y=20.000000 Z=-0.750000 V=8
    G1 X=0.000000 Y=0.000000 Z=-0.750000 V=8
    G1 X=5.000000 Y=0.000000 Z=-0.750000 V=8
    C=0
    N X=0 Y=0
    Line 17 is "N X=0 Y=0".
    I have not found any reference to "fset" or "xMETA".
    Any help would be greatly appreciated.
    Gary
    Jun 2012
    For what it is worth, the trouble is with the C=1 line. C is the tool offset setting and 1 puts the tool on the right side of the cut. If I remove the line or set it to 0 the program loads and runs. I would like to use the tool offset value though and I am hoping to use it.
    Jun 2012
    Solved
    I think I have things working. The C=1 is a code to offset the tool to the right of the cut line (C=2 is to offset to the left). The machine needs a little lead in G1 motion to define which is the right side.
    Hopes this helps some one. I till do not know what xMETA is. If any one knows I would like to hear about it.
    Take care.
    Gary
    Feb 2014
    record 220 with num 1040 controller
    Hello ,
    I have problem with scm routech record 220 with num 1040 controller.
    Do you still have your cnc ?
    please contact me by [email protected]
    Dear Friends
    i work now with Artcam and i can get the g code from this program for the xilog plus (xxl ) , i don't have any problem for this steps.
    Q: When i read the g code for toolpaths profiling ( Along - Outside - Inside )
    i don't find the c=0 or c=1 or c=2 .
    how can i add this command (c=0, c=1 , c=2 for example ) without any problem.
    also i need reference command book for xilog plus.
    please could you help me
    May 2014
    45
    Re: record 220 with num 1040 controller
    Do you still have a scm routech 220?
    Thanks Ben
  1. Xilog Plus
    By Ambic in forum Uncategorised CAM Discussion
    Last Post: 02-07-2014, 03:07 PM
  2. Online cnc programing/ offline cnc programing
    By grimantas in forum Polls
    Last Post: 11-28-2012, 02:03 PM
  3. Record 110 and Xilog Plus
    By YorkyJD in forum CNC Machining Centers
    Last Post: 03-01-2012, 06:45 PM
  4. Record 130, Xilog3 and Programing
    By dnormand25 in forum CNC Machining Centers
    Last Post: 07-31-2011, 02:12 PM
  5. Xilog Plus - Aspire - Routech Record 132
    By Rampage Dave in forum WoodWorking Topics
    Last Post: 10-23-2010, 10:14 PM
