585,880 active members*
8,851 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol > Mazak Tech In house - Turret Alarms - Parameter for delay
Results 1 to 2 of 2
    Feb 2007
    102
    Hello all,
    I have a Mazak Tech here right now and we are trying to suss out the source of my 221 alarms (Turret clamp sensor malfunction).
    The nature of the product line requires a somewhat unbalanced turret and my theory is that the programmed delay time between the 'clamp' command and the 'in position' signal from the prox may be too short.
    Does anyone have a parameter list regarding turret operation? Fusion 640T, QT250HP. I'd just like to have it to bring to the conversation since we have a tech available as we speak.
    Oct 2009
    15
    AL221 Turret Clamp Sensor Malf probably can happen because Home Position for it is gone.
    and maybe battery's MRJ2 for turret is also drain.
    hopefully this can solved ur problem.
  1. Mazak ST40N ATC Alarms
    By Mert-G in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 10-28-2019, 11:29 AM
  2. SOLVED...Mazak QT20 several alarms
    By SINUMERIKO in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 01-08-2010, 07:10 PM
  3. Service Tech and In House Eng. WANTED!!!!!
    By coalstove in forum Employment Opportunity
    Last Post: 06-10-2008, 02:12 PM
  4. Mazak alarms strike again
    By trademarkmachin in forum DNC Problems and Solutions
    Last Post: 09-02-2007, 09:05 AM
  5. Mazak T1 Alarms
    By mbpp in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 06-21-2007, 05:27 AM
