585,975 active members*
4,537 visitors online*
Results 1 to 13 of 13
    Mar 2009
    82
    Mach 3 on a thin client?
    I'm building a new system for my cnc mill and would like to contain all the computer within the machines original control panel, where there is limited space. I've used a mini itx motherboard before on another machine, but when searching fleabay it occurred to me that there are thin clients that meet the spec of mach3's minimum requirements. These look perfect because of how compact they are, also they are super cheap! I'm just wondering if anyone has had any experience with running mach3 on a thin client at all? I was looking at the HP t5720 for example.
    24221
    I have used Panel PC's for a while now.
    POS (Point of Sale) terminals are also a candidate with touch screen.
    Al.
    Albert E.
    Mar 2009
    82
    Thank for the reply Al,
    Yes thats a good point, 1 of those might come in handy for another project I'm working on too! I'm still intrigued about the thin clients though... the machine it will control is a Bridgeport series 1 cnc
    The picture above shows the control panel in question. I'd like to incorporate a touchscreen with custom switch panel on the front and mount all pc hardware inside the box.
    24221
    This was a couple I did some years ago.
    Panel PC.
    Al.
    Albert E.
    Mar 2009
    82
    This is exactly what I'm thinking about doing. Nice panel graphics by the way, how did you do them?
    24221
    I use a local engraver that does reverse engraved Lamacoid, the legends are filled in with paint, the nice thing about this is you can select colours and the front is perfectly flat, so not only does it not rub off, easy to clean, there are no grooves etc for grease to fill!
    I just email him a DWG file.
    Al.
    Albert E.
    24221
    One other example.
    Al.
    Albert E.
    Feb 2006
    1072
    I am running my Tormach PCNC1100 on a t5720 with Mach 3.043.066. It runs nicely, and subjectively "feels" the same as the former Dell B110 that had been running it since it was new in fall 2006. It took me two weekends and several evenings to sort out what services to strip out of the canned XPe install. I "bricked" the first one at least 6 or 7 times and had to start from scratch and reinstall the stock disk image each time--fortunately that is easy to do with the bootable thumb drive disk image loader. Unfortunately, the disk image writing utility included with the t5720 XPe doesn't seem to work, so I had to repeat the manual process with the second t5720 now running my lathe. Fortunately, that was easier having finally surmounted the learning curve with the first one.
    Randy
    Apr 2004
    52
    I have just started playing around with a 7520 and a 7540. I am making progress and i think you need to make sure there is enough memory in the unit. The 7520 I have has 512meg for voth ram and rom. Not sure this is enough. The tool path seems to be slugish. The 7540 has 1 g for both and I it appears to work fine. More set up tp do but I think the thin clients definantley are capable,
    Nov 2012
    1267
    I am running Mach3 on a Pentium 4 630 with 1GB of RAM, and it does just fine.
    Problem is, the Geode NX 1500 CPU in the t5720 thin client is quite a bit slower than my Pentium 4. So I would look for something else unless I could get it really cheap (I'm talking $20 shipped cheap).
    Feb 2006
    1072
    Quote Originally Posted by 2ndSteel View Post
    Lucky! Mine are 512 flash / 256 RAM. But they do work well. I ran a 2-hour contouring program on Saturday on my Tormach, the longest single run I've done on the t5720 so far. They are very stripped down, single-minded machine controllers. Nothing at all that wasn't in the XPe distro, except Mach3 itself.
    You can turn off the toolpath display with a button on the diagnostics page but I haven't needed to. My display window isn't huge.
    I didn't think the 5740's had parallel ports. Are you using yours with a SmoothStepper or similar?
    Quote Originally Posted by CitizenOfDreams View Post
    ...I could get it really cheap (I'm talking $20 shipped cheap).
    My t5720's were $20 each but I picked them up locally from the seller.
    Randy
    Feb 2006
    1072
    I suppose that evaulating the suitability of a t5720 will depend on what it takes to run your steppers. I'm running at 35kHz kernel, and on the Tormach at 10000 steps/inch my rapids are 90 ipm which it does handily. If you need a faster kernel speed to support your motion, it might not be as suitable...
    Randy
    Apr 2004
    52
    5740 does not have pp so ia am going to use with smooth stepper (usb). I do have it communicating with the ss but still have set up to do.
  1. Replies: 4
    Last Post: 06-24-2011, 06:14 AM
  2. beginning of letter to you client
    By Nemo1985 in forum Community Club House
    Last Post: 12-17-2009, 09:12 AM
  3. Very thin bearings ?
    By Bob Shaw in forum Linear and Rotary Motion
    Last Post: 09-23-2009, 08:18 PM
  4. thin workholding
    By tonyaimer in forum Tormach Personal CNC Mill
    Last Post: 09-25-2008, 08:47 PM
  5. Confused: Mach Turn, Mach Mill, Mach 2/3 ?
    By CanSir in forum Mach Software (ArtSoft software)
    Last Post: 02-16-2007, 11:41 AM
