585,902 active members*
4,427 visitors online*
IndustryArena Forum > CAM Software > CamBam > Setting tool offsets and tool change position.
    Jan 2012
    How do you get cam bam to automatically put in the g commands for the same z for tool change?
    Also how do you get the machine to add G43 to the code to apply tool offsets with out having to add it manually?
    I'd appreciate the help.
    Feb 2005
    521
    Quote Originally Posted by trishbits View Post
    If you use different tool numbers in your drawing, CamBam will automatically insert tool change commands when the tool number changes between machining operations.
    You can customize the tool change code by ediiting the 'Tool Change' post processor property.
    There is more information regarding post processors here...
    CamBam 0.9.8 documentation - Post Processor
    This also can be done by modifying the 'Tool Change' post processor property.
    For example, here is the tool change command from the 'Fanuc DK' post that is installed with CamBam...
    Code:
    {$comment} T{$tool.index} : {$tool.diameter} {$endcomment}
    G28 G91 Z0
    G90
    T{$tool.index}
    M6
    G55 G0 X1. Y1.
    G55 G0 G43 Z1. H{$tool.index}
    Note, in the post processor properties you can use CamBam specific macros {$...} or you can just enter plain text you want to be output to your gcode.
    www.cambam.co.uk
  1. setting the tool data and the tool offsets
    By Michael82 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 05-01-2022, 03:10 AM
  2. setting tool offsets
    By 356911914 in forum Hardinge Lathes
    Last Post: 02-08-2013, 05:33 PM
  3. Replies: 4
    Last Post: 02-01-2011, 03:10 PM
  4. tool offsets setting
    By coykiesaol in forum Mastercam
    Last Post: 11-30-2010, 09:46 AM
  5. setting tool offsets? 0M
    By OC_ in forum Fanuc
    Last Post: 02-05-2007, 01:52 AM
