585,761 active members*
3,980 visitors online*
IndustryArena Forum > MetalWorking Machines > Toyoda > Toyoda FA-800 tool changer? hates me!
Results 1 to 5 of 5
    Jun 2012
    125
    The tool changer is giving me fits. Firtst it gave me an AL37 alarm, I had T1M06: as 1 line. The tool changer crashed into the spindle and now the tool changer will not reset. Through MDI I can only make the 2nd swing arm turn left or right. Nothing else seems to finish it's cycle. I have tried to follow the flow chart in the book but It does not seem to help me.
    Dec 2005
    20
    Give me the whole scenario, i.e. you called the tool, it indexed the magazine, it pulled the tool etc. Where did it end up? Do an M915 to close the ATC door as a start and make sure the door closed confirmation is made.
    Jun 2012
    125
    I called Toyoda and they had me do abuch on things i cant remember. It ended up being some setting somewhere.
    Dec 2005
    20
    Yeah all of the information for ATC such as what tool is in the spindle and what tool is in the transfer arm or sub arm, is located in a Data table that allows you to reset the info to what is true, as opposed to what the machine thinks.
    If you go to the table that begins with D0174, that table contains all of that info.
    Jun 2012
    125
    RAC where is the info for this table spelled out? What bit number is what?
  1. Toyoda FA-800 B-Axis? hates me!
    By tjamscad in forum Toyoda
    Last Post: 02-08-2013, 07:50 PM
  2. Toyoda FA-800 pallet changer? hates me!
    Last Post: 02-08-2013, 12:14 AM
  3. Toyoda Tool Change Issues
    By smokeshow in forum Toyoda
    Last Post: 09-25-2012, 01:12 PM
  4. Oversized Tool on Toyoda FA550II 15M
    By Garban in forum Toyoda
    Last Post: 03-20-2012, 02:47 AM
  5. Toyoda Tool change help
    By frank12933 in forum Toyoda
    Last Post: 03-02-2011, 06:04 PM
