Hello to all. I am from Croatia. I'm new here and CNC tehnology is new to me. I was creating things from wood - hand made.(mahagony, teak, etc.)
I have started to build CNC which will help me a lot.
So far I have managed to weld table (140 cm x 70 cm) from 2,5x2,5 cm iron cube pipes. For rolling system I have used 608 bearings and aluminium pipes (2cm x 2cm x 25 cm (wall 2 mm)) rolling on stainless steel cube pipes (2,5 x 2,5 cm (wall 2 mm)). Y axis (support and construction) is welded from iron cube pipes (2,5 x 2,5 cm) and track is made from cube stainless steel pipes. Bearing system like for X.
Now I am in situation that I must design Z axis but I need to have dimensions of a router. I hope I will achive CNC to have X120, Y50 and Z15 cm working area.
CNC will cut wood like I said (mahagony, teak, laminated wood and so.). All parts are designed from iron and stainless steel except bearing system.
Can you please advise me which router should i buy for this purpose? Inexpensive ones have the advantage. (220 V, 50 Hz Eurpean standard) Some e-bay links or other web shops?
Thank you in advance.
P.S.
I hope you will be able to understand my english.
