I am having some trouble with a current project. We are drilling and tapping into the top of some steel screws (4135H, as far as I can gather from the manufacturer). The idea is that we will be setting a magnet into the head of the screw, which we have been doing for a little while. The first few parts were made by a guy who is no longer with the company, and he left very little information behind when he abruptly departed. They are socket head cap screws, 5/8-18, and we are drilling into the center of the head, in line with the screw, and milling out a circular pocket in the top, so when the magnet is placed, it sits neatly where the hex wrench would go, protruding just slightly from the top of the head. We have a program that is running, and has run for a while, but we are breaking drills and taps at an uncomfortably fast pace. We run 30 parts at a time; two or three cycles run just fine, then a tool breaks. There is a stop between the drill and tap cycles to make sure the drill hasn't broken. We are running an uncoated HSS 4-40 spiral flute tap and a #38 drill, which is way over the standard #41 drill. We've used carbide drills, but we broke the last one we had, so now it's back to high speed steel. The HSS drill is running at ~75 FPM, .001 ipr (2822 RPM, 2.822 ipm). I just turned the speed on the tap up from ~3 FPM (100 RPM) to ~10 FPM (340 RPM). The drill had been peck drilling, .02 peck depth, to -.875, and the tap was going down to -.6875. I just moved the drill down to -1.125 to make more room for any incidental chips, although it is a spiral flute tap.
That's as much relevant information as I could think of on the spot, so now the real question is, is there something fundamentally wrong with our method (speeds, feeds, etc.)? I have a lot of will, but next to no experience when it comes to this grade of steel. We typically work almost exclusively with aluminum around here. I appreciate any help!
