584,858 active members*
4,558 visitors online*
IndustryArena Forum > CAM Software > Uncategorised CAM Discussion > Converting turbo cad into a dfx file
    Feb 2013
    I have turbo cad 19 how do I turn my drawings into dfx files so I can run them on sheet cam?
    May 2004
    4519
    If it is possible, your program should have a Save As command. See if you can select File Type > DXF. If this function is not available, look to see if your software has an Export function. Read the Help topics for your software. If you are still confused at this point, computers are not in your talent pool. Turn it off and go watch reality television for a few years.
    Oct 2007
    9
    Moroni, if you need any more help with TurboCad go to TurboCAD Forums - Index. It's a very good forum with out any dip's on it.
    Feb 2013
    Thank you
    Thank you that helped greatly. Appreciate your help.
  1. Replies: 8
    Last Post: 05-04-2015, 12:49 PM
  2. Converting a pdf file to UG part file
    By gaoxingdcf in forum UG NX
    Last Post: 05-20-2010, 01:47 AM
  3. converting a mastercam 9 file into a Solidworks file
    By Michael82 in forum Solidworks
    Last Post: 04-17-2009, 07:14 PM
  4. Help converting .fgc file
    By slammedxonair in forum DynaTorch
    Last Post: 02-12-2009, 10:19 PM
  5. Converting a .max file
    By DAB_Design in forum Uncategorised CAM Discussion
    Last Post: 01-28-2005, 08:00 PM
