586,005 active members*
4,946 visitors online*
Results 1 to 12 of 12
    Feb 2013
    Unhappy Bridgeport series 1 interact
    I need help. I have an old bridgeport series 1 interact with a heidenhain 145 controler. Monitor packed in and then the controler. I got the controler repaired but lost the paramaters in the process. I downloaded parameters from the heidenhain web site but they don't seem to work. Z axis seems to reg. ok but x and y both rapid into the extreme limits when they touch the reg. switch. Any help would be greatly appreciated.
    Tommy.
    1121
    look in the heidenhain parameter thread there should be some that are close.
    heidenhain would not have bridgeport parameters on their site.
    probably counting direction is wrong
    Dec 2011
    63
    I too have a Series I Interact, though with a 151B controller. Attached are my parameters, known good for my machine. Also attached is a scan of Bridgeport's original paperwork with machine parameters from the factory - about everything is the same, but my backlash parameters have changed a little.
    Attached Files Attached Files
    Feb 2013
    Hi Gus,
    Thanks for the quick response. What I can't understand is why in rapids into the limit cams. It normally reaches the ref cams and stops and I can then move manually away. When I change the counting direction and press the ref cam by hand it still rapids the direction it was moving for about 10-15mm and then gross positional error. I have some new parameters I can try and see will it change things. Anymore ideas would great.
    Tommy.
    Feb 2013
    Hi jmccracken,
    Thanks for your post. I will compare your parameters with what I have and try a few changes. There are not as many parameters in the Tnc 145 as your 151B.
    Tommy.
    Nov 2004
    3028
    Could you have a open tach (velocity) loop?
    George
    Nov 2004
    3028
    George
    Dec 2011
    63
    Regarding machine parameters, I'm attaching a short document with the 151B machine parameter definitions. This might make it easier for you to corelate your parameters with 151B's ...
    Feb 2013
    Hi George,
    I'm pretty new to this and I have no idea what that means.
    I have come across the name Al Machine shop in the UK so I will give him a ring Monday and see if he has any ideas.
    Tommy.
    Nov 2006
    925
    Tommy,I saw your request and meant to send you the parameters and forgot.PM me if you want them,I have an identical machine.
    OTOH,Ali will be able to help you.
    Nov 2004
    3028
    The motor has 2 armatre wires and 2 wires that are smaller for the tachometer. There is a seperate section of the motor with its own brushes that acts as a generator creating a voltage that is relative to the speed of the motor and the control/drive watches this. Usually the issues I have with the tach is that it gets dirty and the motor starts to move with a slight shudder and thus needs cleaning.
    Maybe in your case it is open (has a broken wire).
    George
    Feb 2013
    I'm back in business again. I got some parameters that did the trick. Thanks to all for your help, much appreciated.
    Tommy.
  1. Bridgeport Interact Series 1 Mk2
    By AdeV in forum Bridgeport / Hardinge Mills
    Last Post: 09-03-2012, 11:34 PM
  2. bridgeport interact series 1 mk 2
    By skippyfix in forum Bridgeport / Hardinge Mills
    Last Post: 11-04-2011, 02:56 PM
  3. bridgeport series 2 interact 4
    By dcchip in forum Bridgeport / Hardinge Mills
    Last Post: 11-15-2010, 11:47 PM
  4. bridgeport series 2 interact 4
    Last Post: 05-01-2010, 01:27 AM
  5. Bridgeport Series 1 Interact
    By zorba99 in forum Bridgeport / Hardinge Mills
    Last Post: 06-11-2008, 01:59 PM
