I am looking to see if anyone has good post for a Trevisan Machining center with U axis head...? Esprit cannot figure out how to modify a post to create a consist program to reduce errors and
Operator edits..
Operator edits..
how do you set up your U axis machining? are you looking to do milling and turning with the same post or do you use the trevisan to just do the U axis boring? I've done posts for U axis machining on a Mori MH-503 with D'Andrea head, used work offsets for each port center and programmed them with a custom U axis post I built myself...
