585,969 active members*
4,425 visitors online*
    Feb 2013
    Rigid tapping
    May sound stupid but can an intergrex rigid tap or should a sprung holder be used
    Jan 2007
    243
    If you have the Mazatrol 640 MT Control it can rigid tap. If you need some help with tapping formulas try here: Tapping and Threading Formulas
    www.WebMachinist.Net
    The Ultimate Online Source for Machinist Related Stuff!
    Feb 2013
    Machine is an intergrex e670
    Mar 2005
    988
    Since you're UK, I'm not sure what's standard or option but there's a couple ways to check....
    Look on your OPTIONS page in the control and see if it's lit up. Should be something like "SYNC MILL TAPPING" (I think it's option #28).
    Other than that, you can test the machine. Write a simple tapping program and go through the motions on the machine using G84.2 for synch tapping right hand threads.
    If the machine goes through it, you have the option. If you don't have it, you'll get an alarm for "option not installed" or something like that. If you don't have it, you'll need a spring head and use standard G84 code.
    It's just a part..... cutter still goes round and round....
  1. Replies: 24
    Last Post: 05-01-2014, 07:02 AM
  2. Rigid Tapping
    By cncfish in forum Fadal
    Last Post: 12-09-2009, 01:06 AM
  3. Replies: 13
    Last Post: 07-04-2009, 12:43 AM
  4. Tapping head or rigid tapping
    By Gregory_C in forum Syil Products
    Last Post: 10-18-2008, 06:49 AM
  5. Rigid tapping or tapping head
    By kentavv in forum Charter Oak Automation Support Forum
    Last Post: 09-24-2006, 06:08 PM
