585,766 active members*
4,175 visitors online*
IndustryArena Forum > Material Technology > Metallurgy > Do I need to anneal the 4130 rods?
    Nov 2012
    This is the first time I will be turning 4130 rods on a lathe. Can I turn them as is or is annealing required?
    I'm not sure you can get 4130 so hard it can't be turned, however it comes in a wide variety of hardness. Most times it's purchased at the final hardness required then machined. Saves a trip to the heat-treater. Either test the hardness or try a piece.
    Nov 2012
    Can't test hardness.
    Should I be able to use HSS tool, or do I need carbide/TIN?
    OOPS, sorry, false alarm! It cuts like butter with HSS, so all tip top.
    May 2004
    4519
    If you can't test the hardness how do you know it needs annealed?
    If you can cut into it with a file, you can cut it with HSS. Run appropriate speeds.
    Nov 2012
    Intimidated by new material I just paniced.
  1. Do I need to anneal these Lowes aluminum rods before bending?
    By pacocap in forum Bending, Forging, Extrusion...
    Last Post: 04-21-2021, 02:41 PM
  2. Canadian suppliers for drill rods and threaded rods
    By deejayspinz in forum Want To Buy...Need help!
    Last Post: 08-31-2012, 10:02 AM
  3. 4130 chromo
    By mordantly in forum Welding Brazing Soldering Sealing
    Last Post: 12-28-2008, 06:35 AM
  4. Filler Rod for 4130?
    By Chris64 in forum Welding Brazing Soldering Sealing
    Last Post: 09-30-2007, 06:01 AM
  5. 4130 Steel
    By FAMOUSX1 in forum Material Machining Solutions
    Last Post: 10-12-2006, 05:16 PM
