hey folks. im new to here and new to building cnc.
i used to work as a "grinder hand" in a tool and die shop. i've run a cnc moore jig grinder that i had to modify feedrates in the g code, so im not totally ignorant of cnc.
ive got a hf micro mill right now. and i would like to convert it to cnc.
i want to go 3 axis, with enough power to do aluminum and steel.
i also plan to upgrade the spindle motor and run it with a timing belt.
i like the ballscrews and nuts available from http://www.homeshopcnc.com/page2.html
i have a surface grinder that i can do od grinding on, so i can make the ballscrew ends fit into bearings and i can make all the nessicary motor mounts and bearing houseings.
what i am not comfortable with is drive and motor selection. i do however really like the "400 oz/in Model # RHT34-400 Dual Shaft: $85.00" from homeshopcnc.
will they be powerful enough for my needs?
is the Geckodrive G201 good for them??
motors 3 x 85.00 = 255.00
drives 3 x 107.00 = 321.00
ballscrews and nuts 125.00
this puts my approximate cost at 701.00 not includeing all the bearings, aluminum plate, hardware and motor connection components.
will the dual shaft motors allow manual cranking when powered off?
what is a good way to couple the motors and ballscrew ends??
thanks,
nate.
