585,982 active members*
4,669 visitors online*
Results 1 to 9 of 9
    Nov 2012
    139
    Windows 7 install problem with KMotion
    I'm trying to install KMotion429 on a Windows 7 machine. I don't get any errors, but it seems to fly past the install with actually doing anything. Nothing gets extracted, no shortcuts are made. As far as I can tell, it's not doing anything at all.
    It says "Welcome to Install Shield Wizard", I click "Next", the blue bar quickly moves a couple of times for a second or so, and then it disappears without seemingly doing anything.
    I'm hoping someone can give some suggestions for getting this up and running on Windows 7....or DOES it work on Windows 7? I thought it did.
    Thanks for any help,
    John
    Jun 2007
    3757
    This often works.
    For a start right click the install program, and make change compatibility for XP.
    Then
    Start, right click computer,
    properties,
    Advanced System settings,performance
    Settings button,
    Data Execution Prevention tab,
    Add the install program to the list.
    Once installed you may need to add the installed .exe files and .dlls to this list.
    Earlier programs, pre vista/win7 often executed program fragments in data space.
    To allow this you need to add to this list.
    Interestingly, some installs are smart enough to add themselves and other items to this list.
    This works for countless older compilers, programs and some win98 programs too, instead of an expensive upgrade, as well as lots of viruses.
    Sometimes you need a reboot, but most times you don't
    24221
    Did you check to see if there is a root directory created Kmotion429?
    And if there is any content?
    Al.
    Albert E.
    Nov 2012
    139
    I'll try neils suggestion this morning when I'm back in the shop.
    Al: There's nothing at all installed. I even did what I NEVER do and I used Window's search function. I never need to resort to that, but I did it because I was desperate. As far as I can tell, not one nibble makes it to anywhere. I have it running just fine on my CNC controller laptop. I'm trying to get it onto my development machine so that I can write a GUI front end for it that makes more sense for the kind of work I do. What's odd is that I think the laptop is a Windows 7 machine too. The power cable just died on it so I can't check, but I don't recall having any problems whatsoever on that machine.
    If I get it to work, I'll let you guys know what I did. I wish there was a way to log Install Shield. I thought it was /debuglog, but that didn't work. Funny, I got into instrument building to GET AWAY from engineering and software, and I'm probably writing more real software now than I did my last 6 months at the "real" job.
    May 2006
    4045
    Hi John,
    It normally works ok on W7 32 and 64 bit. But the old Install Shield we use has some quirks with certain programs. Exit everything you possibly can and disable any anti-virus and run as administrator. If that doesn't work you can always just install on another machine and then copy in the directory which is pretty much all the installation does.
    If you find something please let us know.
    TK
    http://dynomotion.com
    Nov 2012
    139
    Quote Originally Posted by TomKerekes View Post
    Hi John,
    Thanks, Tom. Do I need to register any dlls, or anything like that? I'll play around with it some tonight and tomorrow, and see how I end up.
    May 2006
    4045
    No
    TK
    Nov 2012
    139
    Just a quick update: The laptop IS a Windows 7 Home Premium machine, just like my workstation. Works on the laptop, not on the workstation. I tried all of the suggestions...nothing works. I even changed my theme back to the Windows Classic theme (that's what I'm running on the Laptop). Nothing works.
    The one bit of info I have is that the installer never exits. The window disappears but the process never dies and I have to kill it by hand. Not sure how helpful that is, but I don't really need it to run on this particular machine so I'm just going to let it go and I'll copy the files by hand as you suggest.
    I also could not install kflop on windows 7 , installation compatibility not help me. But after some time I accidentally found an old freeware Russian program for CNC and starting install, kflop suddenly woke up and established itself ..
    Perhaps the program change something in the system and it make possible to Kflop install correctly! ..
    The program name is PAUK
    download site: http://www.x4axis.com/download.htm
    download link: http://www.x4axis.com/download/setup_no_buf_50.exe
  1. How do you install HeeksCAM from github onto Windows??
    By noobCNC in forum Uncategorised CAM Discussion
    Last Post: 02-20-2018, 06:26 AM
  2. Sprinter Easy Install Tool for Windows
    By crob09 in forum News Announcements
    Last Post: 08-27-2012, 04:29 PM
  3. Post Processor won't install on Windows 7
    By logan1005 in forum BobCad-Cam
    Last Post: 06-15-2012, 04:02 AM
  4. GibbsCam install on Windows Vista
    By bender68 in forum GibbsCAM
    Last Post: 12-12-2010, 02:21 AM
  5. Trouble Finishing Windows 98 Install
    By Jim Stein in forum Computers / Desktops / Networking
    Last Post: 10-23-2004, 01:42 PM
