Originally Posted by
sperman
This is a .0625 DOC, .160 WOC. It is a 1/2" 4 flute end mill running at 3000 RPM and 15 IPM. GWizard recommended slower RPM and faster feed, but it was even worse at those settings.
I've got several hours left before I'm done with this fixture. I'm afraid the end mill will be shot long before the job is done.
The endmill has about 1.4" of stickout. I know a shorter endmill would be better, but it is the shortest endmill I have.
Tormach Cutting Steel Fixture - YouTube
While waiting for the movie to upload, I went to 3500 RPM and 20 IPM and it is better.
What kind of cutter is it? HSS or carbide? If it's HSS your spindle speed is way to fast. If it's carbide, your feed may not be high enough.
You need to be using coolant. In your video it looks like you are trying to run your cutter dry.
At that speed if you're running a cutter with sharp corners the first thing you're going to do is going to be knock the sharp corners off. Now you have flat corners and you are no longer cutting the material, you are just pushing it out of the way, and the longer you abuse that cutter, the louder it's going to get.
It's going to be hard to get your cutter stick out less than 1 1/4 inch because if you try, the run out on the flutes will be inside your tool holder.
You might have better luck if you use a stub end mill.
A good cutter for what you are trying to do there would be a Duramill WhisperKut. It's a 3 flute wnd mill with a .020 to .030 corner radius, and I speak from experience when I say you can really haul ass with them. I used to cut 4340 steel at 2600 RPM, .375 DOC, .188 wide at 30 IPM with a 1/2 inch end mill. But I was using a FADAL that weighed 9,000 pounds, and had a 22 horsepower spindle.
I would say that with the cut you discribe in your video, that cutter will do well for you. Only problem is, they are a little on the pricey side at around $60.00 each.
You need to remember though, "GOOD TOOLS MAKE CHEAP PARTS".
You can buy GOOD PARTS or you can buy CHEAP PARTS, but you can't buy GOOD CHEAP PARTS.
