Hello everybody,
I tried to setup my motors in mach3 and I've noticed that those are skipping steps when jogging in Motor Setup . I'll try to post a video when I get home.
The motors are not shaking back and forth like I've not connect them properly....just not moving round and smooth.
What can be the problem?
In Mach3 I started with 2000 or 1800 steps per mm , step & direction pulse set to 0 . Tried different speeds and velocity with the same result. Could it be that the pulses are coming too fast for the driver to process ?
__________________________________________________ ____
The scenario is as follows:
Unipolar Motors 6 wires
Astrosyn type: 23PM - C109
5.4 V/phase , 1.5 A/phase , 1.8 deg/step
Unipolar Driver based on ICs L297 & 74HC08
Intel i3 with PCI Parallel Port Board and Windows XP
__________________________________________________ ______
