585,692 active members*
5,098 visitors online*
IndustryArena Forum > MetalWorking > Diemaking / Diecutting > Embossing die advice for 0.027 inch aluminum
    Aug 2012
    279
    Wanting to press a simple design into prepainted aluminum coil stock. Have thought about trying to make the blocks on a CNC router from some hard wood like oak or osage orange just to make a few pieces and see how it goes but the finer lines of the lettering might be a problem. Complete newbie to embossing but from some reading I figure I need both male and female dies (rather than male pressing into rubber block). What is a reasonable minimum line width to not damage the paint (seems to withstand brake operations very well)? How do I estimate the force needed? And what is a inexpensive material to make tooling for a few hundred pieces? Make one side and use epoxy to cast the other half? If I make one side how do I cast the other side with enough clearance or do I need to make a negative for each half?
    Hoping to use a Whitney 5 T bench press.
    Dec 2005
    13
    Make one side of steel, the other of polyurethane. It comes in different durometer #, hardness from McMaster-Carr etc.
  1. Bending 1/8 inch thick 7075-T6 aluminum
    By MrFightGuy in forum Bending, Forging, Extrusion...
    Last Post: 08-16-2015, 06:20 AM
  2. First attempt at embossing thin aluminum.
    By Sonicmook56 in forum Diemaking / Diecutting
    Last Post: 04-09-2011, 07:00 PM
  3. Best way to mount 1/16 inch ball mill with 3/16 inch shank in router.
    By cjjonesarmory in forum Metalworking- / Woodworking Tooling / Manual Machining
    Last Post: 07-02-2009, 11:38 AM
  4. How to bend 3/16 inch 6061-T6,T11 Aluminum rod
    By plaz in forum Bending, Forging, Extrusion...
    Last Post: 03-13-2009, 09:48 PM
