Coolant resistant? = it will get wet, but it doesn't like it
It is only 125 in-lb torque, which is about 8 ft-lb.
It is not a worm gear drive, so it lacks the mechanical rigidity of a real rotary table. A worm gear reacts against the worm which passes the reaction on to the bearing housing. The back drive effect on a worm drive is small. However in a spur gear drive such as this, the total stiffness is totally dependant on how stiff the motor can hold it, which is not very stiff at all, when it comes to milling forces.
However, if you can simply use it to index, and then figure out a way to externally clamp the platter, it might serve some purpose to a hobbyist.
