585,760 active members*
3,833 visitors online*
Results 1 to 17 of 17
    May 2010
    94
    Favorite Bells and Whistles
    Over the years browsing these forums I find there are many different machines of many forms, fits, and functions. Some of the things that make the best machines though are the extra's.
    What I would propose of this thread is to see and talk about many of those extra's people have designed into their machine that make using the machine so much easier.
    This could be your favorite dust shoe design, table clamps, xbox controller for commands, table t-slots, router enclosures, quick change collets.
    I will try to post a couple of my favorite things later. I am currently redesigning my machine and would like to include some of these favorite known working solutions. As many others also redesign constantly, I am sure this will benefit everybody.
    :cheers:
    Apr 2006
    3206
    A pallet with rubber mat.
    So I can look at and operate the control without having to stand with my head cranked back like I'm looking at the ceiling.
    Whose frikn' great idea is it that controls have to be mounted at 6' high??????
    Sep 2006
    6463
    Hi, I take it you mean for DIY mill design.......
    A poor mans VFD.....the vari pulley drive with stepper motor control and digi readout of RPM.
    A dual Z axis drive to get the heavy head casting up to the top for big jobs and down for small jobs while having a quill drive as the main Z axis movement for sensitivity.
    A main body casting and carriages etc cast in alluminium bronze....I hate cast iron dust.
    Ian.
    Aug 2011
    999
    - Sliding dust protection covers that don't reduce travel and keep the rails and ballscrews clean
    - Air cooling the liquid cooled spindle with the dust extractor that also eliminates the need for a separate dust shoe. Instead, adjustable height dust skirt with lighting that does not move up and down with the spindle.
    - control software on a netbook that is mounted to an articulated monitor arm: flexible control screen, PC power not interruptable, minimal wiring and no ground loops (isolated wall wart supply).
    Jan 2012
    105
    One of my favorite is the detachable touchplate. When I get done I just unplug it and hang it on the wall. There's no wire getting tangled up in your clamps, fixtures or work piece.
    Jul 2009
    690
    How come nobody has mentioned the almighty SuperPID? :cheers:
    http://www.build.cl
    Jan 2007
    209
    My favorite tool for building my machine is the Magdrill. So much easier than moving heavy steal beams just to drill a hole or two or 100. Move the drill instead and have it stay in place! I found a 'Chinese' one on ebay for $350 bucks. I've drilled hundreds of holes with it.
    Andrew
    May 2010
    94
    Here is something I got in today that seems to have potential.
    Shop fox D3347 cam clamps. $10.35 on amazon. [ame="http://www.amazon.com/Shop-Fox-D3347-Cam-Clamp/dp/B00012XE0A/ref=sr_1_1?ie=UTF8&qid=1362177930&sr=8-1&keywords=shop+fox+cam+clamp"]HERE[/ame]
    Seem to have a pretty good holding force. Used in standard t-tracks. Tested them out real quick like today. with two holding a piece on opposite sides of eachother there is good holding force. I am thinking about making a zero'ing corner on my machine and clamping against that corner for quick setups.
    These things are great, take 2 seconds to clamp a piece down. 15 seconds to clamp a different size piece down.
    Jan 2012
    My favorite is the drill-press laser guide I adapted (last post in this thread: http://www.cnczone.com/forums/diy-cn...f_machine.html), very handy for quick setups.
    The monitor arm to hold the netbook is definitely in my future...also need a place to hang the Playstation controller.
    Aug 2011
    999
    Quote Originally Posted by Lee DeRaud View Post
    .....The monitor arm to hold the netbook is definitely in my future...
    I used[ame="http://www.amazon.com/gp/product/B000ID7QNI"] this one.[/ame] Only $15 and very solid. Sorry about the big image, don't know how to link it smaller.
    Jan 2012
    Quote Originally Posted by JerryBurks View Post
    I used this one. Only $15 and very solid.
    Looks good, but what do you bolt it to? I was envisioning something more like this, which I could attach to the side/end of the table, but it's like 10X the price.
    EDIT: found this one, which is more reasonably priced. It's grossly inadequate for any monitor I've ever owned, but the netbook only weighs 2lb or so.
    Aug 2011
    999
    ....Looks good, but what do you bolt it to? ....
    Any available vertical surface, beam or bracket. I happen to have a vertical outboard plate but if your machine does not have anything like that you need indeed to find something else.
    I have the netbook roughly at table height and can tilt it horizontally and vertically to suit the best view (I frequently work with the door open in sunlight). When I don't need the machine I close the display and fold it vertically flat against the machine so it is out of the way and does not collect dust on the keyboard. There is a thin plywood plate with a ledge attached to the monitor arm and the netbook is strapped with a 2 thin ribbons across the lower corners and fishing line across the top to that plywood so it can still be operated and closed. They are not really designed to be permanently mounted and it took some experiments. I am still going to make some kind of a fabric hood for better protection and because the netbook gets extremely hot if it is sitting in the sun for a while.
    Jan 2012
    ...I have the netbook roughly at table height...
    Ah, got it. I've got a flat front plate at 36"-41", but mounting there puts it a bit too high if I'm sitting and a bit too low if I'm standing, which got me looking at arms with vertical motion.
    Nov 2006
    1036
    Quote Originally Posted by tkubic View Post
    Shop fox D3347 cam clamps. $10.35 on amazon. HERE
    I bought 4 of these a while ago. Fit and finish was terrible. I was able to get them to work though. Here's a link: http://www.cnczone.com/forums/diy-cn..._t-tracks.html
    tkubic Guest
    I bought 2 of the shop fox clamps to see how they would work. Screws were too short to do anything with so I had to replace them. Other then that they seemed fine, only had two though. Will have to put them to use with actual cutting at some point.
    Feb 2009
    499
    I made the one below, here are some more pictures of making it.
    "72.6 per cent of all statistics are made up on the spot." - Steven Wright
    It's looks so good. You really made a good one.
  1. Your Favorite Material
    By wolfau in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 03-01-2013, 03:23 PM
  2. New VF-7 spindle whistles at high rpm!!!
    By paulpe99 in forum Haas Mills
    Last Post: 08-16-2011, 06:49 PM
  3. Bells and Whistles
    By Riverside192 in forum Centroid CNC Control Products
    Last Post: 01-06-2006, 07:30 PM
  4. What is you favorite printer?
    By cncadmin in forum Printing, Scanners, Vinyl cutting and Plotters
    Last Post: 09-25-2005, 03:21 AM
  5. Mastercam Jingle Bells
    By Rekd in forum Mastercam
    Last Post: 01-02-2005, 08:20 PM
