585,762 active members*
4,263 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > PMC-L OE1 and OE2 combining to #ex
Page 3 of 4 1234
Results 41 to 60 of 70
  1. #41
    Dec 2015
    171
    Quote Originally Posted by CNCtam View Post
    Thank you so much.
    I have just sent you 2 files 0E1 & 0E2. Please help me to covert to Ladder files and remade 2 new 0E1 and 0E2
    Very appreciate your help!
    i already sent you file on your email & your welcome mate.
  2. #42
    Aug 2009
    44
    Re: PMC-L OE1 and OE2 combining to #ex
    Is this the case also with fapt ladder for dos, runing on a standard pc with serial port?
    I try to download a ladder i wrote for my machine/compile with a fapt ladder on a standard pc with serial port but when i press F6->F3 i got a red message on the pc screen
    "Port initialize error serial port communication is impossible"
    The pc which the fapt ladder is running was able to receive the parameters i send from the OM-F controller, so the cable->serial port is ok.
    The cable is just a three wire connection, do i have to use the 5 wire cabling, with handshake, or this is not importand?
    Any help will be appreciated.
  3. #43
    Aug 2009
    44
    Quote Originally Posted by tc429 View Post
    send me your binaries, I'll burn'en, upload thru the pcwriter and send you back the fladder files.
    I looked into this a while back, the data is like the merged ex file, BUT they changed from binary to hex or something similar in the output- but think the sub2 break points are added in also...I couldnt sort it out for sure, but I cant do a lot of things
    if you have the fladder, just leave the chips out, boot up, hit 1 to upload your new edited ladder from fladder(f6/f3/f1 to send thru a normal serial cable)...but it will get lost eventually if you dont put the chips in it. Ive forgot to burn chips a few times and the ladder got dumped, once I did it myself and I KNOW i hit 3 not 1, yet 'ladder not exist' msg popped up as If I hit 1.
    just this afternoon I had one running on ram, for curiousity tried loading the ex file from procomm instead of fladder, wasnt really surprised, but no it didnt read it... figured there would be some control strings sent first, never snooped the communications to see what goes in when uploading to the pmc.
  4. #44
    Quote Originally Posted by geast1967 View Post
    Try powering off the PC and don't start any other communicating between the machine and laptop. If I start my PC without anything connected to the serial port I still don’t get that alarm. Sounds like the serial port is tied up with whatever you did last with it. Or you have a blown port. Did you try to go both ways with communicating?
  5. #45
    Aug 2009
    44
    It's a standard ibm compatible pc running pure msdos 6.22, nothing else.The serial port is checked, because i could receive the parameters send from CNC.
  6. #46
    You can receive the parameters but can you send? Fladder needs to see it go bothways.
  7. #47
    Aug 2009
    44
    Ok i did not check that. I will do it on Monday and lets you know. Thanks for the tip.
  8. #48
    Aug 2009
    44
    I finaly managed to send the PMC programm via serial. The problem was that the ms-dos directory was not shared and for some reason i don't know the fladder gould not initialize the com port.When i include to the autoexec.bat the command PATH=C;\MSDOS;C\FLADDER it worked. So i was finaly able to send the *.#ex file to the OM-F.:wee:
  9. #49
    Mar 2008
    27
    GEAST1967
    TWO TO ALL
    COULD YOU HELP ME WITH THE STEPS YOU FOLLOWED TO REACH YOUR SUCCESS
    I WANT TO DO THE SAME ON MY LATHE THANK YOU AND I HAVE THE FAPT LADDER II SOFTWARE ON WINDOWS 98
    THANK YOU
  10. #50
    Aug 2009
    44
    Yes i can help you, but what i did was with Ladder I.
  11. #51
    Aug 2009
    44
    Dragonbikes, please clear your inbox, i can't send you pm.
  12. #52
    Mar 2008
    27
    READY
  13. #53
    Mar 2008
    27
    [email protected]
    Thank you
  14. #54
    Jun 2021
    Post Editing GPP file
    hi Guys
    I need to edit my GPP file to enable block numbering. I have changed some statements but it is not work properly. please suggest something to do it properly.
    here is the picture of my GPP file and program after editing
  15. #55
    Aug 2018
    8
    Hi, could you help me please with the steps?
  16. #56
    Aug 2009
    44
    Yes. Tell me what you need.
  17. #57
    Aug 2018
    8
    How send .#ex file to fapt ladder, step by step please.
  18. #58
    Aug 2009
    44
    You need to run Fapt ladder I.
    Go from main menu to menu "F4 - DISCOMPILE", then input the ROM format file name, like : ROMFILE.#EX and the source file you want to be created, like: LADDERFILE.#LA.
    Then press EXEC and your file will be created.Click image for larger version.
  19. #59
    Aug 2018
    8
    Thanks. I had already been able to do this. But how convert bin files to #ex, or how download ladder direct of cnc... on fanuc 0 series.
    I use this app, but it doesn't work.
  20. #60
    Aug 2009
    44
    I send the two binary files OE1 and OE2 to a person here in the thread you will find his email, and he did the conversion. I don't think fapt ladder I can do it.You need to combine the two files OE1 and OE2 to one binary file and then make it .#ex
Page 3 of 4 1234
  1. Combining SolidWorks and art
    By twoartistic in forum Solidworks
    Last Post: 07-18-2013, 04:50 AM
  2. combining 2 stl objects
    By Gallchobhair in forum Uncategorised CAM Discussion
    Last Post: 10-13-2012, 04:09 AM
  3. Combining DXF in A9CAD
    By blue_steel in forum OpenSource Software
    Last Post: 01-30-2009, 01:38 AM
