585,752 active members*
3,878 visitors online*
IndustryArena Forum > Community Club House > how to cut both side melamine chipboard without chipping
Results 1 to 10 of 10
    Mar 2013
    please give me some suggestion to cut the chipboard without chipping.
    Jul 2004
    127
    Clamping a sacrificial piece of wood to the blowout side of the cut usually helps. Are you cutting with a table/circular saw or a router bit?
    -Matt
    Mar 2013
    im cutting with cnc router- 400.00 rpm_/feed rate ratio 7.0. i has used many type of 6mm bit such as single flute, double flute, 4 flute but all my bit was burn when i cut 2-3 pcs double side melamine chipboard 4'x8'.
    Sep 2009
    1856
    you can get cutters made for what you need they up, down cut spiral bits.
    http://danielscnc.webs.com/
    being disabled is not a hindrance it gives you attitude
    [SIGPIC][/SIGPIC]
    Dec 2007
    362
    Is that a speed of 400 or 4000rpm? Either way, it's too low.
    Try it at a much higher speed i.e. 18000rpm
    Regards
    Geoff
    Mar 2013
    I have trying 20000, 30000 and 40000 rpm for spindle speed.10000 mm/min for feed rate and 4000 for plunge rate but it make me like ****
    Sep 2009
    1856
    get one off the cutters ger21 says to use run about 18000 rpm i have used these cutters they work fine the cut was made at 1500mm/sec 18000 rpm
    [SIGPIC][/SIGPIC]
    Mar 2013
    alright dude... i'll try it. my bit just delivered from Australia 6mm Z2 compression spiral bit. hehehe
    I'd use a 10-12mm bit, rather than 6mm.
  1. DIY Cutting machines for cardboard or chipboard
    By the1toyplace in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 01-06-2013, 11:43 PM
  2. Through Boring 3/4 Melamine
    By Closetguy in forum WoodWorking Topics
    Last Post: 07-03-2011, 02:29 PM
  3. Replies: 13
    Last Post: 07-13-2010, 05:23 PM
  4. Z-axis - mounting rails on spindle side, rather than tower side
    By guru_florida in forum Linear and Rotary Motion
    Last Post: 02-01-2008, 01:54 AM
  5. Chipping melamine edge during a cut.
    By ynneb in forum Community Club House
    Last Post: 03-17-2005, 03:02 PM
