585,991 active members*
6,540 visitors online*
    Oct 2008
    2100
    G320X Fault Source
    Err / Reset Fault Indication.
    Is there a way to determine or indicate the fault source?
    Bob La Londe
    http://www.YumaBassMan.com
    Oct 2008
    2100
    The reason I asked this question is that I have a drive that sometimes faults, but even when I can get it to do it while monitoring the drive I can't determine the exact reason. I do not get a yellow warning indication that it is getting out of position before it faults, and it is not over current as the total current for the power supply is not over the current for the one drive when it happens.
    My only other thought was encoder circuit noise, but ... well see my other post.
    Bob La Londe
  1. Fault/Reset circuit for G320X drives
    By ZincBoy in forum Gecko Drives
    Last Post: 12-14-2016, 10:06 PM
  2. Z Axis fault Error #16 Resolver Fault
    By centaur91 in forum Fadal
    Last Post: 10-06-2012, 05:01 AM
  3. 139 x motor z fault and occasional ground fault
    By duckslayer in forum Haas Mills
    Last Post: 05-10-2012, 01:50 PM
  4. Replies: 3
    Last Post: 05-18-2011, 05:26 AM
  5. Inverter fault / Drive line fault ?
    By TMILLS in forum Fadal
    Last Post: 10-21-2010, 03:20 AM
