585,975 active members*
4,635 visitors online*
IndustryArena Forum > MetalWorking Machines > HURCO > Hurco BMC40 with UltramaxIII reboots by itself
Results 1 to 12 of 12
    kbtownsend Guest
    Morning, new to this site. I'm maintenance at a stamping plant and our tool room has one of these. She randomly reboots herself and goes into conversation mode. This, of course, removes all the tools and she has to be reprogrammed, part picked back up, etc. Following the advice of my normal tool room contractors, I have swapped out the power supply with rebuilt ones a few times and each time it has helped for a month or so. The last time I bought a brand new one and put it in, again helped out for awhile. Now she's back to rebooting randomly again. Can someone help?
    bloke Guest
    Fans. The ones on the card rack - make sure they aren't seized or running hot. Also check all the door fans aren't misbehaving. Disconnect and replace any that are.
    kbtownsend Guest
    Aha. On the door to the power supply cabinet one fan was seized, and the cooling fins looked like someone stuffed a small cat in there. Also no working fans on the Y and Z axis drivers. We replaced all with floor stock and will cross our fingers. Thanks much, bloke.
    Apr 2013
    I have a hawk 5m that has the same problem can anyone help
    Aug 2011
    We have a BMC 40 that has this problem. Check voltage at the power supply, then at different locations along it's path until you get to where the voltage is read by the software. There is so many connections in between that it will loose a half volt on the 5v. That's enough for the software to tell it has low voltage and shuts down. Sometimes just unplugging connections and replugging them in will fix the problem for awhile.
    Apr 2013
    When it restarts the start / power /hold /cycle buttons light up and the coolant pump runs for a few secents the it restarts and will not boot from hard drive got it to boot from the floppy drive it ran for about 30 min then did the same thing can anyone help
    Jun 2008
    1104
    Sounds like your power supply is failing. Do you have access to an oscilloscope?
    Apr 2013
    no checked it with a meter get 5.13 vdc
    Jun 2008
    1104
    Try checking it with the meter set to AC volts to see if there is any noise on the supply. Another thing to try would be to re-seat the memory on the CPU.
    Apr 2013
    I get 1.8 mV ac. One of the fans on the card rack was not working replaced it and it runs fine now thanks for all the help
    Is overheating a common problem?
    Jun 2008
    1104
    No, but as components get older, they are more likely to be sensitive to changes. Normally a jammed fan will generate heat instead of getting rid of it.
    Jan 2019
    4
    I have a ultimaxII that has the problem on booting it displays message"machine configuration defaults have been loaded and needed to be verified" machine display only x,y,z values and thos message.
    can anyone help[/QUOTE]
  1. Hurco BMC40 z axis reset
    By bezelchuck in forum HURCO
    Last Post: 01-12-2019, 09:12 AM
  2. computer reboots
    By slawek297 in forum HURCO
    Last Post: 03-07-2014, 01:29 PM
  3. VF2 Reboots on own
    By dingo0722 in forum Haas Mills
    Last Post: 10-24-2012, 08:53 PM
  4. Hurco BMC40 linear scale conversion
    By brueckstueck01 in forum HURCO
    Last Post: 10-14-2012, 11:18 AM
  5. Computer Reboots?
    By CNCRob in forum Computers / Desktops / Networking
    Last Post: 09-22-2006, 02:13 AM
