Bill,
I believe i did see you
post that! Thanks for the replying.
I am fairly new to my VMC and I am complete rookie to running and programming macros
Because i was having the problems viewing the 8,000 and 9,000 programs I loaded it as a 3000 program just to try it out.
It was a while since i tried it so i don't quite remember what was working and not working but part of the way i was getting confused was the actual process...
for example if i were to load it to program 05000
i would go to the memory option,
and enter G65 P5000 S2 (that tells the controller i want to run a macro with program number 05000 and configure it to work offset 2..
Then i would go jog and move to the correct location,
Then select auto mode, cycle start.
Then select jog go to the next location
for the 3 points....
once thats done it should overright what ever data is in g55 right?
For the program.... this is what i will use... does it look ok?
O5000(CIRCLE THROUGH 3 POINTS MACRO)
M00 (MANUAL TOUCH 1 - THEN CYCLE START)
#1=#5021 (1ST X)
#2=#5022 (1ST Y)
M00 (MANUAL TOUCH 2 - THEN CYCLE START)
#3=#5021 (2ND X)
#4=#5022 (2ND Y)
M00 (MANUAL TOUCH 3 - THEN CYCLE START)
#5=#5021 (3RD X)
#6=#5022 (3RD Y)
(GET PERPENDICULAR BISECTOR OF #1, #2 and #3, #4)
#7 = [#3 + #1] / 2
#8 = [#4 + #2] / 2
#9 = #3 - #1
#10 = -[#4 - #2]
(GET PERPENDICULAR BISECTOR OF #3, #4 and #5, #6)
#11 = [#5 + #3] / 2
#12 = [#6 + #4]/ 2
#13 = #5 - #3
#14 = -[#6 - #4]
(SEE WHERE THE LINE INTERSECT)
(X-CENTRE)
#15 = [#8 * #10 * #14 + #11 * #10 * #13 - #7 * #9 * #14 - #12 * #10 * #14] / [#10 * #13 - #9 * #14]
(Y-CENTRE)
#16 = [#15 - #7] * #9 / #10 + #8
(RADIUS)
#17= SQRT[ [ [#1-#15]* [#1-#15] ]+[ [#2-#16]*[#2-#16] ]]
#[5201+[20*[#19]]]=#15 (X WORK SHIFT)
#[5202+[20*[#19]]]=#16 (Y WORK SHIFT)
M99
