585,604 active members*
3,451 visitors online*
IndustryArena Forum > Employment Opportunity / RFQ (Request for Quote). > RFQ (Request for Quote) > North America RFQ's > RFQ - two parts fabricated from 1/2 x 1" x 6" steel using slitting saw
    Feb 2013
    11
    I have two parts that I would like fabricated from steel. I've designed the parts so that they should be able to be fabricated using 1/32" slitting saws (possibly ganged) and from 1/2" x 1" x 6" bar.
    The two units are part of a press that squeezes thin plastic and embosses it with a pattern. I would like to replace the parts in order to change the pattern. (The two pieces that I need do not interact with one another, each presses onto a flat receiving surface).
    The top surface of the pattern needs to be a flat plane. The pattern itself doesn't require an excessive level of accuracy - I'm assuming +/- .005" is reasonable to achieve?
    The hole sizes are sized for tapping M8 1.25 thread.
    All dimensions in inches and fractions of an inch.
    Destination: Vancouver, BC or Blaine, WA 98230
    Please message me via this site if you have any interest.
    Thanks.
    Rusty
    PDF Files:
    https://dl.dropbox.com/u/66199725/Rusty1.pdf
    https://dl.dropbox.com/u/66199725/Rusty2.pdf
    Jul 2005
    12177
    I sent a PM
    Feb 2013
    11
    Thanks to those who looked and those who quoted.
    This RFQ has now been sourced from the USA.
    Thanks.
    Nice day!
    If you need the oversea Manufacturer' help, we might give you a favor.
    I am Peter From Duch Group which has helped many companies to complete the process from Design to Product in industrial design field all around the world for more then 10 years.
    We wish can be your partner in below fields:
    •Product Designing-- (confidentiality agreement)
    •Prototyping & Mock-up,
    •3D Printing,
    •mode Making/Pilot Run,
    •silicone mold
    •Injection Molding,
    •Small & big batch production,
    •Assembly processing.
    •Product Packaging
    If you have some projects recently,please don't hesitate to contact me. A Free, Fast & Friendly Quotation Service is sincerely provided here.
    All the best,
    Peter
    Attachment 205782
    Duch Group - Xiamen Duch Precision Molding Technology Co., Ltd
    Xiamen(headquarters),Suzhou,Beijing
    Tel: +86 592 3862897
    Fax: +86 592 3862808
    Phone:+86 15880652978
    Skype: DuchGroup.Peter
    Web: www(dot)duchgroup.com
    Add: #899, Maqing road, Haicang district, Xiamen, China
  1. Replies: 5
    Last Post: 03-14-2013, 05:18 PM
  2. Slitting Saw in 12L14 Steel
    By racecraft in forum MetalWork Discussion
    Last Post: 09-22-2010, 03:27 PM
  3. Need resources for having front end of concept car fabricated from foam
    By bladex1 in forum CNC Wire Foam Cutter Machines
    Last Post: 08-25-2008, 04:03 PM
  4. Replies: 5
    Last Post: 07-16-2008, 08:25 PM
  5. RFQ for steel parts
    By 98vert in forum Employment Opportunity
    Last Post: 03-04-2008, 10:02 PM
